Clk light defective
what wattage brake light and reversing light bulbs have you fitted?
B
benzonthemenz
  • #42
I think it maybe could be the unit, but bulbs are always blowing out all the time.
If the bulbs are always blowing, then do check the running voltage, 14.2 is the absolute max, better at 13.8volt
Simply put a voltmeter across the battery when the engine is running, that will tell you
whitenemesis
CLS55 AMG '05
As Alex, double check you have the correct bulbs fitted as a first check.
Is there a cluster readout of voltage? Or is the car too old for such a display?
i see problems like this so often, sometimes i am told that all the lights work, and all the bulbs are correct.
usually i swap a bulb, or replace a blown one and all is good again.
Cluster and STAR voltages are no where near exact, that is a fact
B
benzonthemenz
  • #49
I fitted 21 5 and changed it for 4watt. All bulbs are correct, I think it's to old for the cluster voltage display. Or how would I get it up?
Yes a 208 will not have this facility I think
whitenemesis
CLS55 AMG '05
If available, usually by a combination of IGN positions and holding the ODO reset button but I have no inkling about this car
B
benzonthemenz
  • #53
Please can you give me a list of all the rear correct bulbs and lights Please. Another question I have 2 lights on the front on twin head lights, there's 2 xenon bulbs, 1 small 1 on eitherside, and 2 large xenon bulbs. The 2 large ones have never worked or lit up? Why are they there, and only the 2 tiny xenon bulbs work???
Makes you wonder why MB would bother with it then?
Is it available on the OP's car?
It is a rough guide and used on STAR so that one can see if it is all going to crash, though it does warn you first, since the top of the battery is the best bit, but this can go down rapidly from this point onwards
B
benzonthemenz
  • #55
do you know how to turn on the front fog lights?
all the bulb wattages at the rear are clearly written on the bulb holders.
B
benzonthemenz
  • #57
Of course I know how to put the gigs on by pulling the switch out once or twice, it's not the high voltage, I never new the holders have the correct bulb filliment
B
benzonthemenz
  • #58
There's 2 bulbs they don't work and never have since I owned the car, I'm not sure what lights they are or supposed to do as they've never worked, that's not causing the light defective. I will get to the bottom of this though.
B
benzonthemenz
  • #60
21 4 watt, exactly as it says on the fitment box,now I've changed my main beam As they wernt working, but light defective still come on. Now I found my rear foglight didn't work on the boot lid. Changed, still light defective????
