CLK W209 Driver side electronics
taybz
W209 - CLK320 Petrol
Hi All,
wonder if anyone can help with an issue i have, this only happened on Friday and its very annoying. (W209 Coupe - 03 Reg - 3.2L)
so, the following has just started happening:
1. key in ignition and a get a sound from the speakers? (very Confused)
2. Electric Seat adjuster has stopped working (Driver Side)
3. Boot and electric windows module not working (Driver Side)
4. Wing mirror controls all dead (Driver Side)
5. most importantly, when the doors open and close the windows manoeuvre into place and out again. this has stopped working and now i have a gap between the windows.
note: Passenger side is all fine.
so the above has just started happening and i thought it may be a tripped fuse, so checked all the SAM Units and fuses that relate to the controls and all are fine and dandy.
please Help...driving me insane and i cant figure out what's up with it....
Looking like the N69/1 door ECU, as long as you are sure the fuse for the drivers side is OK
T
taybz
Hi Television,
Checked all the fuses according to the sheet you get attached to the driver side panel SAM. All those fuses where fine. No breaks.
Could you elaborate on the N69/1 door ECU? Would that control driver side and allow passenger to work fine?
The worrying thing here is, jump starting normally blows SAM's and not door controllers. I would get a STAR read out as the windows are CAN controlled from the SAM.
T
taybz
Havent jump started the car, so not sure where that would come into it.
Sorry I miss read that bit, I do that sometimes, so just a failure of the N69.
T
taybz
Haha...no worries. Ive misreqd alot of things in my time.
With regards to N69 as its happening on my driver side, does that mean its the driver side module? Was reading there are door control module for both sides..
N69/1 is drivers door and N69/2 the passenger side the passenger side should still work, I cannot answer whether the passenger side window should still work from the drivers side if the N69/1 is at fault.
T
taybz
Hi all,
so a cousin of mine who works in a garage borrowed the diagnostics software they have not STAR, but i wonder if anyone could help me decipher them.
B120D - M21/1H1 (automatic dimming Mirror)short circuit
B1203 - Component M28M4 head restraint raise/lower (hall sensor fault
B1157 - signal from component S92/4 (assistant driver seat height release microswitch) Error
B1063 - head restraint adjustment standardisation error
B1055 - The component or the signal line to the component S68/3 (Driver side seat belt buckle restraint systems switch has open circit to positive
B102E - the resistance value in the ignition circuit containing component R12/2 (front passenger etr ignition squib) is too low
B102F - same as abve but too high
can anyone assist?
Most reader can do SRS faults and this one has done just that.
As long as your is that one, there are many.
10 A 209 820 02 26 CONTROL UNIT RIGHT DOOR; Replaced By: A2098202226 001
10 A 209 820 22 26 CONTROL UNIT RIGHT DOOR 001
10 A 209 820 01 26 CONTROL UNIT LEFT DOOR; Replaced By: A2098202126 001
10 A 209 820 21 26 CONTROL UNIT LEFT DOOR 001
20 A 209 820 09 26 CONTROL UNIT LEFT FRONT DOOR; F 04773520030220 001
20 A 209 820 25 26 CONTROL UNIT LEFT FRONT DOOR; F 04773620030220 001
20 A 209 820 09 26 CONTROL UNIT RIGHT FRONT DOOR; F 04773520030220 001
20 A 209 820 25 26 CONTROL UNIT RIGHT FRONT DOOR; F 04773620030220
T
taybz
Hi all,
So replaced the DCM on driver side and all electrobics back up and running.
Drivers windjw lowers and raises and other elements are now good.
But...the rear windjw is lowering But not raising...and the rear switch is not lowering or raising the rear driver window. Works from driver side. Tried a replacement rear DCM and to no avail.
Any suggestions?
T
taybz
Apologies, the rear switch is working, just had it on child lock.
So its just the rear window now raising.
Thoughtz
I do not know the definite answer but it maybe programmable.
T
taybz
Ok...so its now all working as it was previously. Seems like the system just needed reminding itself. After a short the reqr window now works.
Replacing DCM did the trick...
Thank you all for your help.
On to the next issue...
Key in ignition and sound from speaker...any takers? :)
What kind of sound ????
T
taybz
  • #18
Like a thud type noise...kind of like when u connect a speaker for the 1st time to the sound system
Is this with the comand/radio turned off.
T
taybz
  • #20
Happen when the key is inserted into the ignition. Nothing else is switched on.
