CLK270 gearbox
Bruce John
CLK270
I have a CLK270 auto 03 reg and drove the car 120 miles to an airport and dropped off passengers. When I drove off the car would hardly go and not get above 2nd gear. I stopped, waited and tried again, same problem. I let the car cool a little and set off again. The car seemed OK then all drive was lost. I stopped, switched off the engine, restarted and drove off. The gears seemed to change then all drive was lost again. Twice when I restarted no gears would engage. After all the stops and starts I gave up and got a lift back for me and the car. There were no fault messages on the dash. Now the car is cold it seems OK but obviously it is not. I am scared to take the car out on any long trips. Does anyone have any ideas? Thanks Bruce
whitenemesis
CLS55 AMG '05
Get it on STAR and have the codes read.
Possibly the electro-plate playing up, possibly low ATF level.
See what others suggest
B
Bruce John
CLK270
CLK270 fault codes
Yesterday I started a thread about gearbox problems on my 2003 CLK270 CDI Automatic that was failling to operate, disengaging while running, not changing up etc. I was told I needed to post the fault codes. I have been informd the faults are:
p2001 etc control modual faulty
p2315 can connection (a1 instrument cluster faulty)
p2600 curcit 87 voltage to low
p2221 signal of y3/6b1 or y3/6s1 implausable
p2500 transmisson has inpermissable transmisson ratio
p2502 gear impermissable or slipping
p220a y3/6n2-y3/6n3 speed comparison implausable
Does any one have an idea what might be the problem.
Thanks Bruce
Steve@Avantgarde
Bristol/Somerset
Looks like a speed plate issue but also a low voltage fault code stored there, I would look at the crank voltage of the battery too, must be 9.6v to power up the ETC, you could have 2 faults there.
