CLS w219 320cdi om642 engine-exhaust...? vibration at idle and when driving at the 1300-1500rpm
Andreyy
w219
Hi.I have a problem. When I smoth reving at idle,when rpm goes to the 1300 I start to feel vibration to the steering wheel and body till the rpm rich 1500rpm. Also,when i driving and make a load,for e.x feel the most when driving at 90kmh,and 7 gear engaged,then engine rpm is in thsi range,and when I start to acelerate,i start feel vibration on steering wheel and body. Also,I noticed,that when I reving at idle with open door,at this RPM range the exhaust start to change the sound,its maybe more louder..the feeling that he is resonating.. I have car for 2 years,and till me the DPF fitler has been removed(I think there is free space in the mufler..DPF taked out ant the muffler with free space in it fited back) Can free DPF muffler(tank) affect it,and exhasut system now at certain rpm starts to resonating and making vibration?Also I cheked all exhaust ruber mounts and heat shields,all is perfect. And yes...this is now the mounts problem,I have new instaled engine and transsmisiont mounts,and its OEM :) Sry for low english :) Please help :) Or maybe in the om642 its normal,and at this rpm the engine runs like a out off balance,and making a slight vibration?
dry run
Portsmouth
kb-boatpark.co.uk
CLS 350d AMG LIne Premium Plus
I would have suggested engine/gearbox mounts, but you say you've had them done??? Sorry, can't really suggest anything further. Maybe find a good MB indy and take it there for an opinion. :)
A
Andreyy
w219
How about torque conventer on this 7gtronic gearboxes?:) But logicaly..on idle when rising the rpm,then cant vibrate?:) How about torque conventer symptoms on this gearboxes?:)
dry run
Portsmouth
kb-boatpark.co.uk
Sorry, don't know much about the TC. I had 2 cars with the 7Gtronic box and never had a problem with the box or the TC. An MB mechanic should be able to scan the car for fault codes and give further clarification on the TC.
pgh13
Nr Leamington Spa
E320CDI 2004 - straight 6 diesel
How many miles and how long since the transmission was serviced ( fluid and filter changed)?
klevis
Registered
E350 CDI 4Matic
Any news? I have E350CDI 4Matic 2011 with the same symptoms.
Any help will be very appreciated.
Thank you!
