Manc Rick
- Jul 7, 2020
- Location
- Manchester
- W213 E220 Premium +, 2017 with OM654.
Hi, I was in two minds whether to post this, as it exposes my OCD side. But b0ll0cks I’ll post it anyway.
I wish in some ways I could go back to the mindset where I used to get in a car and drive, but previous bad experiences (non merc related) coupled with learning more and more (on an amateur level) about the workings of Diesel engines (for instance the vulnerabilities of emissions control devices and turbos when the oil hasn’t fully warmed up) have got me to the point where I listen ‘acutely’ to my car and can pick up even the most slight change of sound characteristic.
Reading about how the majority of engine wear is caused during the first 10-15 minutes when the engine is below operating temp, I’ve now become so bad that last week, when I had to drive a mile to the supermarket and back and it was bitterly cold, I decided (rather than punish the car) to drive to a different supermarket, a few miles away, just to give it chance to fully warm up, rather than get it 10% up to temp, the engine off, then the same for the return journey).
I realise this is ridiculous but it’s where I’m at. I’m constantly thinking, before a short journey, that the oil has sat at the bottom of the sump, cold and thick, and I know that starting the engine up, to drive 5 minutes down the road and back is going to cause wear.
I’m convinced that the cold winters here have a huge detrimental effect on our cars. Over in the Canaries, every other car is a 20 year old merc (not just the taxis) and some of them have done ridiculous mileage. I know they have smoother roads, less rain etc but I’m convinced that they benefit from the lack of sub zero winter temperatures.
Im quite normal aside from car anxiety! You name it, it has happened (mostly in my previous Peugeot 3008)...I even had diesel turning to gelatine due to cold temp, which clogged my fuel filter and caused a breakdown (I believe hindered by sub standard fuel filters which were later ‘updated’).
does anybody else worry about their car in cold weather? Are my concerns justified?
As I say, I wish I could just get in the car, enjoy it, and drive away without a thought, like other people seem to do, but alas, that isn’t me at present.
Also, (partly to settle a debate with my Son) once fully warmed up, is it generally better (for the engine) to drive “like a granny”, taking it easy and letting the gears change quite early on, or is it good to occasionally increase the revs and put your foot down? Is it perhaps better for the engine but worse for the gearbox to drive like a granny?
any views greatfully appreciated.
