COMAND SCREEN FAULT/NOT WORKING 2015 W205 C CLASS 220D
01bowie
C Class 2015 220 diesel
Afternoon All
So I have the COMAND screen problem where the first 2 messages on start up appear (Mercedes Benz Logo and then the warning re distraction when driving) then the screen fades to black with lots of moving lines like an untuned TV. After around a minute it starts again at the start up screen and loops through this as long as it is left on. All functions linked to the module are not working properly - heating, reverse camera, blutooth phone, sat nav etc.
So after reading different posts and forums I got the feeling the fault may lie with a faulty screen so I purchased a second hand screen (part no A 205 900 41 13) which is in excellent condition thinking this will be the answer - sadly not as the problem persists!
Surely 2 screens will not be faulty so any other ideas would be gratefully received....
Other points - there is a cd in the player that is continually spinning when driving - reverse camera comes on occasionally if you reverse with the start up screen just starting and heating display partially comes on if the controls are pressed early on after start up.
2015 W205 C CLASS 220D SALOON
Many thanks in anticipation
rpalmeida
www.mercupgrades.com
Try it without the SD card installed. If thats not it, its likely a failed head-unit although sometimes a software update sort the problem- we're seeing a definite increase in 2015/2016 C classes with failed head-units. Come and see us in Lightwater (M3, J3) (www.comand.co.uk / www.uniquecarsound.com ) and we can diagnose and replace if needed at much more sensible pricing than Mercedes.
Cheers
Richard
  • Like
Reactions: DSK
01bowie
Cheers
Richard
Thanks Richard - SD Card already out - would the still spinning cd in the cd player have any bearing on matters?
Many thanks
Darren Duncan
C220d/2015/2.1
Hi Guys just spotted this my C220d has just got same problem occasionally works for few minutes then dies really frustrating don't want to buy a screen incase something else tried fuse, battery holding eject and reboot same problem anybody find best solution please
Alfie
Surrey/Cotswolds
www.comand.co.uk
Most likely the actual head unit itself. Email us your vin number to sales@comandonline.co.uk and we can quote you for a replacement far cheaper then your local dealer will quote!
chiltls
Leicestershire
C 250 BlueTEC 2014
OMG I have found exactly the same problem I'm having. Is there an easy way that I could confirm where the actual problem is?
I have had the car apart trying to diagmose this issue, but to no avail. I have an OBD reader but this doen't show me anything. The head unit is A 205 900 78 15 (Jul. 2014) if this is the fault would I be able to install a later model. I am based in Leicestershire if there are any of you out there local to me who can assist? VIN. WDD2052082F080725
Markyp33
Registered
E CLass E200 Estate (S211) 1.8 petrol auto
Hi Chiltls
Did you get you probelm resolved - I have the identical issue; also in Leicestershire
saads7
E250 Sport W212
Its a software fault. I had it recently. Nothing to do with faulty screens etc. Visited local coder who updated software. Took 45 minutes and problem solved. My car is a 2015 C220d W205. Coder said gets these all the time, shite software from factory which causes problems over time.
Jonathan Fleming
New Registration
W205/2015/1598 cc
Hi Saads, Did that really fix the lines appearing on the screen ? All roads seemed to lead to new head unit. Was it just a standard software update you got ?
Dave Farnen
Registered
C220 cod 2015
Hi, I have the same problem....2 days old. How do I find a local MB coder, please? I live in Trowbridge, Wiltshire.
