L John
- Nov 24, 2013
- Location
- UK
- W204 C350 Petrol Elegance
Hi folks, hope you're all doing well, I have a problem with command shutting down on my 2008 C class.
It starts up ok but after a random time of around 2 minutes to 10 minutes a pop up message says 'command is now shutting down' then the screen closes.
After this happens my rear indicators stop working on both sides, message shows rear indicator fault after I try to use them. They work fine at start up and are factory leds. My fuel gauge starts to randomly read normal, low or show empty, changing occasionally, and my headlights come on even with the selector set to off.
I know there's a fault on these cars where the brown wire on the harness that connects to the rear light cluster and it was showing signs of overheating so I did the wire bypass that our good friend Malcolm (RIP) recommended many years ago.
Unfortunately it still shuts down and does the other weird stuff.
I'll get it booked in to a good garage well known for doing good work on Mercedes but that will have to wait a couple of weeks.
Until then has anyone got any ides what the issue could be?
Thanks.
Thanks.
