Common sl500 battery drainage
Danoli123
Sl500
Hi .
Can anyone point me to the main area's to check for battery drainage to check on a 2002 sl500 please. Many thanks.
Nigel
Comand system not shutting down
Water damage in the boot
SL63 Mark
The South
R231 SL63 AMG
Could be anything, you need to go through the fuses with a current tester when the car is "asleep", otherwise we are guessing,
Craiglxviii
Cambs UK
Hi .
Nigel
By the way. There are about 130 culprits! You’ll need to test every fuse.
PSE pump. COMAND not going to sleep. Alternator diode pack. Loads of potential causes.
Comand, cd changer, TV tuner, mobile phone kit....
On mine it was Comand related. If I turned off the car and sat for 5 minutes you could periodically hear the CD Changer cycle. Disconnected the CD Changer and TV tuner (both in same area) and battery no longer goes flat overnight. Not bothered figuring out which it is but it's one of them.
SL63 Mark
The South
R231 SL63 AMG
For me it was a slight drain on one of the rear window motors. Depends how big is the drain, 0.30 amps is normal. Anything over 0.50 is a problem, most people fit a trickle charger and problem solved.
I have a 0.35A drain and the consumers message will come on after a couple of weeks. You can connect a meter in series with the rear battery and watch the car go to sleep.
Cole@MBS
www.mbssouthampton.co.uk
Check under passenger side carpet, make sure the small brown and green can block conectors aren’t green due to water Ingres!
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
I fear you've missed out a zero Mark, shouldn't that read 0.03A (30mA) and 0.05A (50mA) for a sleeping state? 0.5A (500mA) is a big number?
Craiglxviii
Cambs UK
I had a 0.4A (420mA) drain that was killing my battery in under 8 hours.
D
Danoli123
Sl500
Ok many thanks ..good man
D
Danoli123
Sl500
Thankyou. Top man
star
Reading
Smart + others :)
Alarm siren?
