Coolant Sensor Problems
CerbyT
Devon and Shropshire
Discovered an airlock in my coolant system after changing a perished coolant pipe. According to Haynes I can bleed it out via the coolant sensor housing. My question is which item on top of the cylinder head is the coolant sensor housing as Haynes (bless 'em!:rolleyes:) dont give you any picture of where it is!!!
The car is a 1989 W124 3.0 SOHC.
Help!!!
IAN MAC
Clackmannan
Why not just take the cap of the expansion tank and run the engine at a fast idle, any air in there will soon find its way out.
( you'll know its clear when the water level drops )
Also by squeezing the bottom hose and the top hose (the big ones) will dispel any air
C
CerbyT
Yep, tried a bit of that this evening. Top hose got quite hot (obviously:Oops:) and felt as if there was not a huge amount of water going through it. Ran it for about 5 mins or so whilst squeezing hoses but not 100% sure if it has worked fully. Just wanted to check via the sensor housing before I set off on a 250 mile journey with the wife and dogs on Friday! I'll give it another go tomorrow.
Thanks for your quick replies chaps!:D
Its a pleasure and good luck, enjoy the drive
