Hi is DOT 4 ok for SBC brakes on a 211 or will I have to get DOT 4 Plus? Thanks
Y yinujim Senior Member Joined Dec 21, 2015 Messages 95 Reaction score 15 Location Essex Your Mercedes 92' 500SL, 04' E500 Estate Nov 6, 2023 #1 Hi is DOT 4 ok for SBC brakes on a 211 or will I have to get DOT 4 Plus? Thanks
onefortheroad Senior Member Joined Dec 8, 2015 Messages 3,451 Reaction score 2,071 Location uk. Your Mercedes Me -2019 GLC 350 coupe AMG line. Mrs- ford kuga 65 plate awd powershift . Nov 6, 2023 #2 It'll tell you on the cap of the brake fluid reservoir. Most likely dot 4 .
OP Y yinujim Senior Member Joined Dec 21, 2015 Messages 95 Reaction score 15 Location Essex Your Mercedes 92' 500SL, 04' E500 Estate Nov 6, 2023 Thread Starter Thread starter #3 Just found out its DOT 4 Plus on the lid. Febi do 5 litres that meets Mercedes spec. https://www.ebay.co.uk/itm/18566989...69nWZIxhEO1Iqz1UP2hCKStIfA==|tkp:BFBM3u-j6fRi
S supernoodle Senior Member Joined Sep 7, 2021 Messages 372 Reaction score 304 Your Mercedes E220 2005 2.1D Nov 6, 2023 #4 I bought some Pagid Dot 4 low viscosity fluid from Eurocarparts recently. From what I could tell that is essentially Dot 4 plus.
onefortheroad Senior Member Joined Dec 8, 2015 Messages 3,451 Reaction score 2,071 Location uk. Your Mercedes Me -2019 GLC 350 coupe AMG line. Mrs- ford kuga 65 plate awd powershift . Nov 7, 2023 #5 No point buying 5 litres , once you open it ,it's absorbing moisture.
OP Y yinujim Senior Member Joined Dec 21, 2015 Messages 95 Reaction score 15 Location Essex Your Mercedes 92' 500SL, 04' E500 Estate Nov 7, 2023 Thread Starter Thread starter #6 onefortheroad said: No point buying 5 litres , once you open it ,it's absorbing moisture. Click to expand... Mercedes mention it needs 3L brake fluid for the procedure. Works out cheaper.
