Correct brake fluid for SBC
yinujim
Essex
92' 500SL, 04' E500 Estate
Hi is DOT 4 ok for SBC brakes on a 211 or will I have to get DOT 4 Plus?
onefortheroad
uk.
It'll tell you on the cap of the brake fluid reservoir. Most likely dot 4 .
supernoodle
E220 2005 2.1D
I bought some Pagid Dot 4 low viscosity fluid from Eurocarparts recently. From what I could tell that is essentially Dot 4 plus.
Y
yinujim
Essex
No point buying 5 litres , once you open it ,it's absorbing moisture.
Mercedes mention it needs 3L brake fluid for the procedure. Works out cheaper.
