Could someone explain the '4k rev limit' in neutral?
D
doversole
Hi all, DoverSole again.
Been browsing the forums as you do, came across various references to the above. I guess it seems logical but i'd welcome an explanation. Strikes me several of us may be a touch relieved to know there's no fault. Certainly no mention of it in the Haynes.
Thanks, Dover
Most MBs will not rev over 4k in neutral, this is purely a safety device as it is not good to go over that RPM without a load,,its un natural
D
doversole
Thanks, Malcolm - I sort of surmised it would be something along those lines.
carnut13
Nr Sherborne, Dorset
R231 SL400 & Audi A1 Sport
In fact most modern engines wont rev much over 3k.. my Jaguar for instance. The Engine Management stops it. Used to give the MOT guys kittens at one time :-D
R
recycledjuvenile
Forget haynes. It is in the merc handbook. fuel cut off steps in at 4k
dragon
Banned
Remember during MOT a couple of years ago to warm up the catalyst, they revved it up to 4K for a couple of minutes made me sick. I complained though and they stopped doing it. They still do it if it not warm enough to fail the emission.
kth286
E320 Coupe 95
Is it on the autos only and to protect the torque converter ?
R
recycledjuvenile
it is on auto or not and it is to protect the engine
moosehead
C230/2005/2.5L Avantgarde SE Sport Pack Estate, SLK230/1999 and Volvo XC60/2017 AWD
I thought this was due to torque convertor stall speed. Probably needs someone with a more technical understnding to explain.
hardtop
south of glasgow
what we need is someone to volunteer to overide it then knock it into drive at 7k to see what fails first ? i think the box
D
doversole
I think the nut behind the steering wheel might fail first - have a hunch.
DoverSole
R
recycledjuvenile
I have a manual and it does exactly the same thing. Does not matter if it is an auto or not
R
recycledjuvenile
it does not in mine
it does not in mine
On many cars in the range if you touch the brake pedal this kills the throttle,,I thought that something was wrong when I first bought it and use the heel and toe technique
