cruise control? c220d w202
davoC220
glasgow scotland
1996 C220 diesel elegance
iv been seaching this topic for a while now, but come up blank! after speaking to a few merc nuts, iv been told that mercedes fitted the loom in the steering column for cruise control on certain models, in my case iv got an elegance, but dont know what else to look for, been on benzworld but all there cars have it fitted as standard (lucky people!), if mercedes did not fit everything, what parts will i need, appart from the stalk (obviously) and i know il have to get it star programmed as well
jberks
I assume its a manual? From memory autos came with cruise as standard.
I thought there was a control box needed - could be wrong though. Also, as the throttles on the 202s were manual cable affairs (my 220 petrol was anyway) I assume you'll need an actuator/ Also assuming it is a manual, does it have a switch on the clutch pedal?
Hopefully Malcolm will come up with a diagram showing the components but I suspect you're in for more than just plugging in the switch as you would be on later electronic throttle models. (As my Brother in Law did with his Saab for example).
D
davoC220
glasgow scotland
its an auto 4 speed, i've not been able to find an aftermarket 1 either, most of my searches give me Carfi, but they dont list the W202 as a model they do, only A Class and B Class
D
davoC220
glasgow scotland
thanks Malcolm, checked that out, works out £550, am seeing a guy form Mercedes Glasgow later to get my outside temp guage programmed, so i'll find out what parts i need for a retro fit, and see if i can get them from a breakers, think this is probably my easiest and cheapest route to go down, keep u updated on it tho
I have sent you the retro fit for the petrol,,it was not fitted on the diesel,,but I will try another one
I have sent another for the 250d let me have you first 6 numbers after 202
D
davoC220
glasgow scotland
your a star Malcolm, the chassis is 2021212F381864, that was the prices conrad anderson and ultimate came up with after speaking with them, so both were the same that way
Thats OK the 30.2 paper that I sent you applies to your car too, and the correct one :D:D
D
davoC220
glasgow scotland
sorry, was editting that last post when you replied, bit 2 quick for my own good!lol
You can get it all from a breaker cheap,,even from a 250d
turbopete
Spennymoor
i had 1 of these with a manual box. the throttle was the same as any other ive owned as it was an electronic pump and had the fly by wire throttle with the cable from the pedal going to a potentiometer (i think thats what theyre called!) and the rest done electronically
jberks
Interesting - my '95 C220 petrol didn't have the potentiometer, but a cable going directly to the injection unit via the cruise control actuator. The first time i saw a potentimeter setup was on my 2000 E240 so I assumed it was a later (post 202) development.
Was I right in thinking that cruise was only standard with the auto boxes?
It certainly looks that way on what I have found
