Cylinder Head Gasket Gone
robertmc
Argyll, Scotland
E220 Coupe 1996, 190E 1993, AC Cobra replica.
Hi folks - I would appreciate some advice!
I have a nice 1996 W124 E220 coupe. It started loosing a little water with no sign of a leak anywhere other than steam and water dripping from the exhaust, so I reckon the cylinder head gasket has gone. I intend to do the work myself. I have done cylinder head gaskets before but on older simpler cars so any advice on removal of the modern complicated bits (and pitfalls to avoid) would be welcome. I have heard somewhere that you should renew the head bolts but why is this and is it required on this model? Thanks.
As Xtractorfan,, these things do work on small leaks,,if it does not then I can give you a few DIYs on changing it
Dave Brooker
Make sure you tension the chain correctly, otherwise you can snap a cam.
R
robertmc
Argyll, Scotland
Thanks very much for your quick replies. I am going to try SteelSeal and will post how I get on with it. Thanks again, Robert
simon_wall69
Stone, Staffordshire
I would double check it is the CHG, they rarely go. Other people have posted about this and have found it to be something else and much simpler - I can't remember what though, sorry.
White230CE
Hertfordshire
1989 W124 230CE
There is a product on the market that seals these leaks, i have heard reports that it works extremely well.. I will chek it out and get a name for you.. certainly worth a try on a '96 motor..
This is the link
http://www.steelseal.co.uk/index.asp?function=DISPLAYPRODUCT&productid=1
Hi Xtractorfan,
Do you know if this is any good as a pre-emptive measure? I don't think my head gasket is going just yet, but if it is starting to go but too early to show symptoms? I intend to renew my anti-freeze and coolant, so is it worth adding this too?
turbopete
Spennymoor
2022 '71' Ford Grand Tourneo Connect (sorry)
whilst im all for making life easier and cheaper, surely this is just a short term fix that will, like rad weld etc, just end up blocking your radiator?
Xtractorfan
S class
Right lads firstly I dont think using it as a pre emtive strike to cure a problem that might occur I dont think so.. but check with the manufacturers.. secondly yes as turbopete and jet tech have said perfectly true .
The only reason i mentioned this is because i got some info on it last year and then heard a lot of good reports about it working.. so my thots are. not for me..but technology has moved on a lot since the good old days and things do now work.. now if I were in the position of removing a head from a 96 motor, or using a new wonder cure I think i would go for the miracle cure..and as it has been road tested and works then it may just do the job
Have to agree that things have moved on, and they get very good reviews in the trade press
turbopete
Spennymoor
but my point was, isnt fixing a head gasket but ending up with radiator blockages a little counter productive?
Perhaps Pete the radiator was partially blocked before it went in, and this has aggravated the head gasket
turbopete
Spennymoor
i meant blocking the radiator with the sealer. if it blocks holes etc then surely it can block the small pipes in a radiator and just make matters worse?
Alex Crow
Super Suffolk
better test for co in the coolant first with leak detector, most garages can do this these days. if the blue dye goes yellow then carbon monoxide is present in the coolant, and can only really come from the head gasket. we do a few on the 111 engine so it is not that unusual. when the head is off check for tracking on the head surface in the area of the leak, if groove/s present then a skim is needed. if you are doing this job, get a haynes manual and follow the procedures - you can't go wrong. head bolts can probably be reused on this engine, check the haynes for maximum bolt length but they are always fine.
Ultymate
N. Wales
C230K Estate 1998
I used a hydrocarbons tester for a couple of years before my retirement and found it a very unreliable piece of kit for diagnosing H/gaskets. I find a pressure tester in the hands of a skilled technician far more conclusive
