De-badging.
dry run
Portsmouth
kb-boatpark.co.uk
CLS 350d AMG LIne Premium Plus
what's the best way to get the E350 and CDI badges off the boot?
Hairdryer + plastic scraper?
Fishing line?
Any other ideas?
Hairdryer/heat gun and fishing nylon or indeed dental floss will work equally as well. Have some IPA ready to soften and remove any residual stickiness. No scraper if you can avoid it
JBell
Torquey
C350 CDi Estate (GAD Edition)
This plus AG SRP to remove any residue
vtaylor78
Northamptonshire.
A little heat (Her indoors hairdryer will do :D) dental floss, and Halfrauds do a product called “Sticky Stuff Remover” which is great and shifts all the residue left behind.
V6Matty
Newark, Nottinghamshire
Any petrol based product will work for removing sticky stuff, WD40 is a good one or Vaseline if it needs to dwell for a little while
mark.s
MBO Forum Staff - CLS 320 (W219)
MBO Ad Sales & Partnerships
Tunbridge Wells, Kent
www.mercedesclub.org.uk
CLS 320 CDI remapped (W219)
Did this to my CLS and got some product from Halfords to get the glue off the bodywork.
For me, on an 08 car it took a long time to come off.
Warmed up area with hairdryer a lot and used fishing reel to slide it behind badges and drag off. then spray the product, wait, clean and repeat for ages.
Good luck
Rob7seven
Poole, Dorset
2020 AMG C300
Maybe slightly less effective than some other solvents, but I've found plain old methylated spirits to be an essential non-aggressive solvent to have around the home. It makes short work of removing any sticky residue after label removal etc, without doing any damage to what's underneath. After the hair dryer/fishing line primary treatment, I'd try meths first, possibly a bit slow and needing hard rubbing, but you have to be careful with modern paints, water-based ones are far less durable than older solvent-based products.
Liam.Moran
2008 CLS320CDI, 1989 190 2.0. 2013 Smart ForTwo
Don’t forget to wax where I’ve removed the badges/applied anything to remove the sticky stuff as you’ll have stripped off any wax (no wax under the letters!)
