Diesel additives - any good
Richard65
Kent
2015 E350 Bluetec AMG Night Edition Premium + 5dr
I've read a few threads with both neutral and positive responses about using additives, like Redex to clean injectors/and other components. My E350 diesel has done around 30,000 and I run it on Shell V-Power and I wondered if it was worth adding Redex or is there something better? Have seen posts from others suggesting adding 2-stroke and others saying Redex can't do any harm but does anyone have any serious use data with definite improved performance and can anyone verify that these products will not harm the injectors or engine.
Why bother on a car with only 30k miles?
Given you already use v-power I can see little point in anything extra.
Redex is not much more than kerosene, an oil fraction not much different to diesel.
Westheath
South London
As above
V-Power
I particularly stopped replacing Audi 3.0 EGR cooler assemblies @ £700.00
and advised customers to use V-Power for 6-8 weeks after testing V-Power
on various engines that had been fed lower grade fuel.
80% cleaned up and dropped the fault code.
Definitely not a placebo effect and no need for anything else to be dumped in the tank.
200ml per tank of mineral 2-stroke can be used on the older CDI engines to lubricate the fuel system when using cheaper fuels or a fuel source that's lower quality.
Later adblue - blue efficiency system should be using higher quality fuel by default and not use any additives unless at the point of service and a recommended fuel system dosing applied to remove/prevent diesel algae forming.
Richard65
Richard65
Kent
Thanks both of you...really helpful....it's a Bluetec so I'll stick with V-Power.
Craiglxviii
Cambs UK
I asked an engine design engineer about these a while ago. His response was, "it can't do any harm".
Really, what they are best at doing is putting money in the hands of the shareholders.
TheBlimp75
Milton Keynes
2005 CLS 350 107k
What about additives for Petrol engines?
Namely a CLS 350 , heard differing stories aswell ?
Anyone got any first hand experience?
Sent from my SM-N960F using Tapatalk
Same as above. I've never felt an additive was value for money.
vtaylor78
Northamptonshire.
E350 CDI Coupe C207 2010 \ SLK 250 R172 2011.
As above
V-Power
Hi Westheath, sorry to jump in on this but I’m interested to find out.
Would my E350, with 111,000 on the clock benefit from running on V -Power ?
Westheath
South London
A lot depends on how you are using your diesel engine.
In my part of the world they potter around never seeing a motorway.
Yet when I'm up at the Leicester or Cambridge workshops those customers are using the M'ways
frequently and this is where diesel engines get to clean up themselves even on cheaper fuel to a certain extent.
Modern diesel engines are becoming more sophisticated and rely on quality fuels and oils to run them.
So give it a go with V-Power, and I mean a good month or so not just £20 here and there,
and see if you notice a difference in mpg return and the general "feel" of the car.
That said I have only recommended it when there's been a fuel related problem,
and when corrected, regular branded diesel is used (non supermarket).
Millers do a diesel additive I've used in the past and always felt it improved the engine feel . Also Archoil AR6400d I've used yearly .
I add an Archoil Cetane enhancer (makes the fuel burn hotter and cleaner) which has a lubricant to counteract the effects of low sulphur diesel fuel . I'll look up this and edit the post (AR6850 is the stuff)
vtaylor78
Northamptonshire.
Only used at weekends, but usually gets a Blatt down a motorway or dual carriageway.
I will give the V-Power a try for a couple of months.
vanmaster26
cornwall u.k.
2009 ML 300 Sport
If you got a Diesel i swear by using 2Stroke Oil google it runs smoother ,quieter,a little more response but the main factor is your adding the Lubricity that being removed by the oil companies namely pulling the Lead out of the diesel
umblecumbuz
Wales and Gozo
Much of this is subjective isn't it?
I also add 2stroke to every tankful, and even if it doesn't do anything it SEEMS to run smoother, and makes me feel better having added it. I even feel guilty if I forget!
But hey, the car goes well enough when I forget. The next person who buys it will do something different, or drive it in a different way, and he'll be happy with his results I'm sure.
I've been doing the same for a couple of years with a mix of Cetane as well , and I'd agree it does seem to be smoother
Gazwould
C250 CDI
I'll always add 2 Stroke when multiple year results from the same Boston derv smoke opacity machine confirmed a halving .
Frontstep
T210 320cdi
Soon we'll be on to the old "supermarket fuel is scraped out of the bottom of tanks by children"
I have been using Costco's fuels they have apparently deposit control agents to keep your internals clean;
https://www.costco.co.uk/fuel-q-and-a
Does it run any better hmm thats a good question.........
Westheath
South London
Oh dear,
Assuming no children are being harmed in this thread..................;)
If you read the thread in its context,
its about how a diesel engine is used versus diesel quality.
In my experience, where I am, they are plodding around in traffic 80-90% of the their life.
And so I find changing to a better fuel quality, when a problem arises,
makes a huge difference when its applied 100% and has cured some common faults.
In other areas I live/work where cars are not stuck in low speed traffic environments,
there are less EGR DPF emission related faults that come to our workshops,
hence no need to be using a higher quality fuel.
I cannot make or prove a direct correlation only what I know from my experience.
If you want to take fuel samples and do comparisons of what fuels are actually doing what, have fun with that.
I can only state what I have personally found in this area over 30 years of diesel repairs.
