Diesel mpg has decreased
Mercbenz123
London
C200/2007/2.1
Hi there
I have a c200 cdi sport 2007 my mpg around town was around 33 and motorways was 45
And now...
Around town is 20 and on motorways is 26 mpg
I have checked the oil, that seems to b fine.. What problems can affect the mpg of a car...
Any help would be much appreciated
Triv
Bristol
A brace of s210 1998 e300 turborustbuckets. Toyota HiLux Surf kzn185 3.0L
What's it's operating temperature? Too cold and it'll be thirsty. If that's the case, it will probably be wise to replace the thermostat.
panason1c
Somerset, UK
During dark, cold mornings/evenings, you will use more fuel due to a longer engine warm-up period and ancillaries such as heated rear window and mirrors, wipers, headlights, cabin fan, etc, put more load on the alternator which creates an extra load on the engine which increases fuel consumption.
Naraic
2005 CL500.
So many views...
Best thing is to get it to an Indi with STAR and get the codes read.
If it had been the oil (though not quite sure what you expected there), the engine would have been wrecked if it was so low as to cause higher fuel consumption.
Stop the guessing...get it read.
Corned
East Midlands
2005 S211 E320CDI Avantgarde
Mine has started taking much longer to warm up in the last few days.
It's the cold weather...
M
Mercbenz123
London
C200/2007/2.1
Operating temp is 80-90 goes up and down
Thanks for replies guys
M
Mercbenz123
London
C200/2007/2.1
What would you recommend and what could be the problem?
tode
NW FRANCE
E300e 2024
'Fraid I'm not very mechanical, but if it's a 2007, then I'd start with change of thermostat.
Should run somewhere between 85 and 90, but stay constant once warmed up.
