Diesel sevicing
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
Hello again, for those of you that do some of the servicing yourself, and this maybe the minor service, which ones do you do?
I used to do oil and filter, and air filter myself. Are the MB engines ok to do at home, or are there any "special things" that a dealer would do as well.
Or am I better off getting a garage stamp on this every time to help with resale values? Not that I am intending to sell my, once I have one.
I have a Clk and E320cdi both 2009 , I do all my own servicing now as I intend to keep them long term . Neither car is worth more than a few thousand each . Because I am doing it all I am changing the filters a lot more often than normal .
If I can't do something I use a good Indy or my local garage
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
Some engines don't have a drain plug, so you will need a pump to remove the oil.
Capra
Capra
Gloucestershire
Pela 6000 on eBay buddy , it will change your life :D
Cheers mate, I did thank you were joking lol. To be honest that is easier than using the plug. Just as long as you can drain properly. Where does it go?
brianbrian
cockney in the West Country
w124 250D, SL129-deisel
Large fuel filter, In line filter, oil and filter, clean air filter , or change if need be, check atf in g,box, renew every 35,000, check anti,freeze strength, oil grease moving parts,throttle linkage, all hinges. I change my brake fluid every 25,000, wheels of check pads and disc,grease wheel bearings, check poly belts, washer bottle.
It goes down the dipstick tube and sucks it out into a container . I never joke about Pela buddy :D
I'm in the process of deciding between the Pela 6000 and a 12v electric, I'm tempted to go for the electric but I don't have any feedback on how good they are or otherwise.
https://www.machinemart.co.uk/categories/?search=engine oil pump
Why would you need to go electric ? For the few times you have to pump the Pela , it's not exactly hard work and at least it makes you feel like you have done something . Pela is a reliable bit of well tested kit . ( other makes are available , and I don't have shares in them ! )
I use a sealey pump. Same idea as a pela and it's brilliant. Don't ever use a sump plug any more even when fitted.
Pump for a couple of seconds, then go make a coffee. When it stops empty it out (two of my cars take 8 litres of oil and the pump is 6 but stops when full). Another couple of pumps on the handle, drink the coffee and it's done.
Capra
Capra
Gloucestershire
Sounds like it could be a tidier job as well. 8 ltrs, that sounds like a lot. But I suppose some of these engines are pretty big.
Capra
Capra
Gloucestershire
Two of mine are V8s and another is a V6....
Nice cars BTW, I remember those cars from the 90's. How long have you owned the V8's for? Did you look at the 600's as well?
One V8 (r129) has been mine for nearly 3 years, the other V8 since august last year and the V6 for 18 months (it was bought to do a particular job which it has done far better than we expected).
I did look at an SL600 r129 but they were beyond my means.
The r230 has specific sentimental value and will be unlikely to ever be sold - it belonged to member (and dear friend) Television who passed away in August last year.
Capra
Capra
Gloucestershire
I'll just set my sights on the V6 for now :)
Craiglxviii
Cambs UK
As LK, one of mine is a V8, one a V6 and the other an I4 soon to be replaced hopefully by another V6.
The V8s are great big lazy engines that make life effortless...
lasa
E Class estate E212/ 2012/E220
Hi Wighty,
I keep a waste oil container that I decant at the recycling point at the local dump recycling centre.
I thought if I use the electric pump I can decant directly to the waste oil container and save decanting from the Pela, not much effort either way I agree, I suppose I am looking for the quickest and easiest laziest method :p.
Havn't made my mind up yet, less to go wrong with the Pela I guess.
Capra
Capra
Gloucestershire
  • #20
Hi Wighty,
Can you take your car to the dump and decant straight from the car? :D
