Diesel System Cleaner in a Petrol Engine
Frontstep
T210 320cdi
Does anyone know any reason why some diesel system cleaner cannot be run through a small petrol engine to clean a carb ?
It might work if you have the engine running and hot
F
Frontstep
T210 320cdi
Its for a Lawnmower to save me going out to get some its either that or strip the carb.
I thought it might be, it should keep running with it in if it is hot
F
Frontstep
T210 320cdi
I had a little read and it appears some are claimed to be suitable for both.
Diesel in itself is a good cleaner, during the Suez crisis I ran my car on the paraffin from street works lamps, had to use petrol to start, then switch over but the white clouds of smoke were horrific and the smell
PeterCLK
Cumbria
2012 204 Elegance saloon 220 cdi
I drove a TVO tractor when I was a lad. Started on petrol and pulled a lever to switch over. Lots of white smoke.
Given the prices of decent law mowers why would you risk it?
F
Frontstep
T210 320cdi
Stripped carb absolutely mint, cleaned tank filter also mint, adjusted cables improved it, changed plug no improvement, changed oil as I had some.
I will adjust the valve clearances to see if it will run a bit smoother.
Honda publish lots of useful papers for the engines.
It not bad too do when you get it off the ground.
F
Frontstep
T210 320cdi
Set valve clearances (if you ever wonder what happens to old coke tins Honda use them for engine covers and stick on with goo).
Sharpened blades as well.
Engine smoother but just not quite good enough for me I will carry on.
Corned
East Midlands
2005 S211 E320CDI Avantgarde
Did you run it without the blade in place? If so was it any smoother?
F
Frontstep
T210 320cdi
I didn't, but I did balance the blades when sharpening them.
F
Frontstep
T210 320cdi
It is a lot lot better than when I started but its not smooth enough for me.
I shall because I am fussy carry on.
