Digibox Convertion, help from Malcolm please (Television)
shagger11
port talbot
sl55 2003
well malcom I actually picked the car up today, apparently the amp was buggered so they changed it, all working and guess what...? it has tv ..!! :)
So im gonna try your method, whats the best and easiest digi box to fit please pal...?
Rob
ps wouldn't it be beneficial to slice all 4 antenna leads into the co ax..?
Oh no one cannot do that, you just cannot parallel coaxial cables. I hit the right one first time, this is the nearest one inwards.
The other antenna's are for other countries in the main.
Rob
There is one on Ebay about £60 again a rip of as not worth more than £20 they talk of twin tuners and that is all rubbish.
shagger11
port talbot
sl55 2003
ok thank you very much, I thought the 4 aerials were just directional...? remember the old days when u had a coat hanger stuck in the back of the b&w tv, then u added another coat hanger, then another, then a bit of wire and eventually getting a good signal.....lol..i thought it might have been the same principal and also thought it might avoid having to park the car at a certain angle, well off to Tesco now to get me a digi box :0) thanks
wish me luck :)
shagger11
port talbot
sl55 2003
ps, do you know any thing about the cd changer....screen says no magazine inserted, but it is, press eject button the green light comes on but it doesn't eject.>???
These can fail in that way, they often come back to life if the fuse for the changer is removed for 20 mins and replaced, failing that it will have to be repaired.
shagger11
port talbot
sl55 2003
just gave it a bang whilst pressing the eject button and out it popped... sorted :0)
shagger11
port talbot
sl55 2003
having trouble getting a 12v digibox Malcolm, all the small ones im finding have the 240v lead straight into them....any suggestions..?
Ignore the booster and antenna, the MB one is very good, you just do not need it.
Note that tuner use an F connector for the antenna, you will need a short piece of coax that you will have to spice onto the existing wire once you have cut the plug off.
If you are unsure I will do a splice and take a picture.
shagger11
port talbot
sl55 2003
thanks for your kind offer, im a 46 year old engineer aka pocher, im sure with all of your guidance notes ill have a ****** good go at it, private plate on tomoz, remap on Tuesday so its tv day Wednesday....watch this space..!! lol
shagger11
port talbot
sl55 2003
ps the kit comes with stick aerial so ill chop the plug with a bit of coax off that :)
Good thinking, I did wonder if any form of antenna came with it, the 50Ω cable is much easier to use than the solid core 75Ω :D
shagger11
port talbot
sl55 2003
quite simple to do isn't it, all in and working, only thing that threw me was that stupid digibox, who would have thought when the red light is on...the box is off and when the light is off the box is on....Chinese aye lol.
Getting about 55 to 60 % signal strength on my drive but all channels are pixelating quite bad, nothing is watchable really. there must be a way to improve that antenna I took the inner lead from the 4 aerials leads( the black tabbed one)....if I cant get a smooth channel I feel as if ive wasted my money and time... :( its horrible being a perfectionist at times LOL
Tel: 020 8863 9233
