Dim HIDs W210
JimM
Berks, UK
W210 E320 CDi Avantgarde Estate 2002
Hi chaps.
Has anyone experienced HID bulbs getting dimmer with age?
Or could it be some distortion or deterioration inside the bulb?
My beams don't illuminate the road past about 12-15 feet, but on a wall the beam height is about correct.
They both are similar brightness to each other but are not as bright as other cars' HIDs, nor as bright as the +130% Xenon Halogen upgrade bulbs I've fitted to my Jaguar.
I've polished the lenses last year and they aren't bad.
So if it's a common fault I'll just get new HID bulbs, or do you have other suggestions?
Thanks.
Craiglxviii
Cambs UK
They do get dimmer with age yes. 7-8 years seems to be the L70 point.
Craiglxviii
Cambs UK
Naraic
2005 CL500.
Hi chaps.
Thanks.
Just get new HIDs (Xenons if you prefer).
You can't put halogens in because the fittings are entirely different.
Craiglxviii
Cambs UK
On the other hand powering a halogen lamp with an HiD power supply might be (briefly) very interesting...
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
I know a lot of people say go OEM or buy a decent brand but in my opinion £40+ per bulb is too much. You do get what you pay for but when you can buy a pair for less than £15 with a 6000k crisp white light which has so far lasted nearly 2 years (famous last words) then it's a no brainer imo
Naraic
2005 CL500.
4300k is oem, may not as white as 6000k, but produces more light.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Are your light lenses still clear or could they do with a polish?
Craiglxviii
Cambs UK
^^^ This. There is a reason why OEMs choose neutral white. Cos it works best.
J
JimM
Berks, UK
Hahaha, it's OK guys thanks, I'm slightly teshnikal!
Right, thanks, I'll probably get a pair of new +50% HID bulbs (pricey still) and a pair of +130% Xenon Upgrade bulbs for my main beams.
I used www.autobulbsdirect.co.uk many times, great service and selection is easy on their site.
Last pair I got were a good price from ECP but they've raised their prices so we need a discount code, which they provide nearly every day.
The halogen headlamp upgrade bulbs are Xenon-filled too so "Xenon" doesn't only refer to HID any more.
Philips recently released +150% "Racing Vision" Xenon Upgrade bulbs by the way.
Has anyone used LED (e.g. Cree) for main beams, are they any good yet?
J
JimM
Berks, UK
Just checked...
HID bulbs (dipped beam) are D2R and main beam Halogen are H7.
D2R HID Bulbs are £64 each for the +50% Philips!
The rest are bright standard output bulbs but still £35 each.
Ouch!
J
JimM
Berks, UK
Slightly dulled but not fogged, I polished them last year.
The bulbs are dimmer than the +130% halogens on my S Type Jaguar when I'm looking at them side by side.
I'll get new bulbs and report back.
Craiglxviii
Cambs UK
You cannot use an LED based lighting engine for a lamp designed for a type of incandescent lighting source, whether filament or metal discharge. They just do not work in the same way and are not interchangeable, nor would they be legal even if they worked properly. Badically the emission gradient of light from an LED based source is completely different to the incandescent source, so the reflectors do not shape the light correctly or the projectors do not focus it. Chalk and cheese.
LED based lighting is of course possible but uses a completely different lamp housing to achieve the end result.
Cree are really not the LED manufacturer of choice for Automotive applications by the way. They set their stall out to develop ever- more highly efficient chips and have done so superbly well, they represent the bleeding edge of the technologically possible in electronic lighting in this respect. However for chromaticity (colour rendering consistency) and light output, the bleeding edge of the market is held by Osram Optoelectronics who are primarily an automotive and marine applications expert.
Most people will steer you to the excellent Nightbreaker series of lamps for good performance.
Naraic
2005 CL500.
When talking cars, Xenon usually means HIDs...is there any question about that?
Now...halogen-xenon lamps...how does that work? Is there a little of each gas in the lamp?
JBell
Torquey
Just checked...
Osram Nightbreaker Unlimited are £14.03 a pair on Amazon, by far the best bulb out there
Osram D2R Xenarc Original +100% 4150k are £37.30 each on Amazon
