dipped beam suddenly too low
davrum60
guildford
ml270 cdi 2000
mercedes C320 cdi sport 2008. taking the car out last night realised the dipped beam was too low or not enough range, realised as was not able to drive as fast I would normally do. both sides the same. Have tried adjusting but though have tried turning adjuster its making no difference. Any thoughts anyone, thanks in advance
Had this recently with my E320cdi , on my car there are 2 self levelling sensors and the metal arms on them are prone to rusting . One is in the front right wheel arch at the top of the suspension Spring . The other is underneath the car above the rear differential .
If the arms are both intact it's probably one of the sensors .
Having your car checked on a Mercedes specific code reader like Star or icarsoft will be able to diagnose the fault as well
  • Like
Reactions: DSK
PB53CLS
Paisley
2010 CLS350 CDI Grand Edition
A new rear unit for my CLS cost just under £30 in December,from MB Grangemouth (delivered to local Arnold Clark)
  • Like
Reactions: DSK
Sidewall
Oxon
R171 SLK 200K
I don't know what system your car uses. Vacuum or Electric.
Had a similar problem with a R170 SLK, turned out to be a vacuum tube leak.
