how did u sort out the red and green light flashing problem? as my car is doing the same thing. was able to get a jump start when the battery went flat and anothe time when i was not sure if battery was flat. still flashing red and green
Following on from this thread, I am afraid that I have been advised legally not to divulge this information. So please do not send me any more requests for it as I cant divulge it sorry. I fully appreciate that the vast majority of enquiries would be from legitimate owners seeking help with their car. However, I still cannot give out the information. Sorry.
If you are stuck with your immobiliser then I strongly urge you to use the mobilo life services.
Thank you and welcomeI'm posting this video (anonymousel annonymously) in disguise to show you how I resolved the no start issue on the Mercedes E320 Elegant.
http://www.youtube.com/watch?v=ZNyu1w8LWbw
STOP emailing me. I dont care if you are GOD I cannot give out the answer.
Hi Alfie, I noticed you have posted several posts to try and stop people emailing you the same question. I need to say that I keep receiving emails asking me if I need Viagra however I've found that IGNORING THEM is far more effective than replying to them.
Hope this information helps.
Regards
Mr Limp.
high luke, where are you located? i have done many many of these, assuming you have the dealer fitted immobiliser. do you have silver stickers in the windows saying 'fitted with an approved mercedes benz alarm system'??
this immobiliser was dealer fitted, not factory fitted, and certainly needs removing. you will find the control unit in the passenger footwell behind the steel plate. look for the yellow/red black/purple wires and trace them to where they intersect the original wiring. simply remake the original circuits and trace all the other wiring and remove as necessary.
I too am desperate to know how to bypass the immobiliser on a c180. The alarm system is failing and I want to turn it off. Any chance you could send me the solution.I had cause many years ago to call upon Mobilo to get my car (W202 C180) going after the immobiliser refused to let go of my car. The car unlocked and locked fine but inserting the key and turning did nothing.
When the chap from mobilo came out he quickly disabled the immobiliser which shocked me when I saw how simple it was. It takes about 5 minutes thats all.
I'll PM you the solution.
EDIT: Cant send you a PM as they are not enabled for you. Send me an email to sales@comand.co.uk and i'll reply with the solution.
Neal
Can you tell me how to disable the immobiliser as i am having the same problem on 1995 c200. Thanks
If your alternative fob is now also working then it is likely that the siren is the cause of the trouble, to test the alarm, try locking yourself in the car and stay still for 30 seconds then open a door to see if the siren sounds.
Some of these sirens have backup batteries which can die/leak and destroy the circuit board inside the siren, replacing the siren could solve the fault.
What is written on the Silver sticker?
Dec
