Do you need any special tools to remove W211 Ball Joints?
B
Brian23
EClass
  • #21
The joint is pressed in, it can be done on the car in half an hour with the right tool, you can get it on that auction site, this is the one I have, item number 262781486151, it's not too expensive, probably cheaper than the labour. You will need a ball joint separator, and some ear plugs for when it releases, replace the other side while your at it too.
Thank you. I have ordered one. Why the earplugs?
onefortheroad
uk.
Good luck with this . I hope it works out for you. Its not as simple as the you tube video. Give yourself a few hours . Just parting the arm from the ball joint can be a task n a half.alot easier on a ramp ,i did both sides lying on concrete pavements.
onefortheroad
uk.
interested to see if it is upto the task ?
They are good for a few uses. The cups are pretty much ko'd on mine after fitting 3 ball joints.
js190d
newcastle
1991 w201 190d 2.5/ 2002 s210 320cdi avantgarde
That tool does'nt look like it is up to the job to be honest. Put it this way you cannot press a lower ball joint in using the weight of the car, that is how much force is needed to install and remove them (on a w201 anyway)
I removed and installed mine using a hand press but it was custom made by a fabricator and was extremely sturdy. Also if the cups are poor quality you run the risk of nipping the ball joints rubber boots and rendering them junk. I would take it to a garage to remove and press in if i was you.
onefortheroad
uk.
Lol. Plenty of folks have used them to great effect . User error can be possible i guess.
bembo449
gainsborough , lincolnshire
I bought a similar tool for doing the rangeys rear rose joints , the bearings shattered first time out so I still had to strip it down and use a press :rolleyes::rolleyes::rolleyes:
onefortheroad
uk.
Once you get the ball joint moving .they come out fairly easier.
Andyn666
2003 W211 E320 CDI estate
Well I've used that a could of times, like I say it took me half an hour to do each side, no bother with it, and it still looks new.
