does anybody know owt about atego 815s?
marsie
We are in the process of converting a box van 2000 w reg Atego 815 into a beavertail transporter but have come across a couple of problems
1-The dash has recently died completely,no clocks lcd display or anything else?? is this a common problem/easy fix?
2-the cab only has a rear spring on the drivers side? is this normal?
Paul;)
Sorry Paul it looks like we know nothing about these
kebo57
Lanc's
ml270
Paul;)
Hi Paul
I have a 814
I have a few links to the Russian web site for MB Trucks you might be able to edit these links as I cant get to the Russian web site from where I'm posting from, one goes to my thread at MB world forum.
http://www.benzworld.org/forums/unimog/1373639-om366a-engine.html
http://www.detali.ru/cat/OEM_MB0.asp?WDB=WDB6740142K046597
http://www.benzworld.org/forums/att...209356050-om366a-engine-wdb6740142k046597.pdf
Kevin
PS would that box be a 20ft ally body, roller shutter back door
M
marsie
Thanks anyway guys,after trawling the internet it appears its a common fault that requires the clocks replacing:(
Paul:neutral:
vauxhallmaniac
SL350/SLK320 Special Edt/SLK320 "Tinkerbelle Edition"
Hi Paul, the atego's only have one spring on the o/s there is a guide on the n/s to align it when lowering, although they are prone to breaking the cab torsion bar's that assist with the raising of it!!!! regarding the dash display if you have the rev counter built into the INS display they suffer with the wiring chaffing under the revcounter so clocks out and have a look behind if you have the casette type rectangle rev counter it may well be a faulty INS these are programed by STAR so substitution with a second hand unit will need reprogramming by a friendly Mercman!!!!!!! for commercial spares try http://www.erithcommercials.co.uk/ they only break Merc Trucks best of luck simon....:D:D
Tel: 020 8863 9233
