simon tompkins
- Feb 29, 2008
hi guys im just about to try and sort my mrs passenger door out,when you lock the doors on the central locking the passenger door just bounces up and down and doesnt lock,so im thinking its the motor i have a couple of qustions if you dont mind.
when i remove the door panel is there anything i have to do with regard to the airbag in the door,also will it just be a replacement motor or is there sometning i can do to fix it, (i no you cant really tell but there might be a common problem)
also the interior is starting to look a little sad is there some way of bring it back to life, (i have a 96 e280 avantgarde and my interior is perfect)
im also going to change the glowplugs on tuesday i have seen the thread on glowplugs,and i have removed the plastic covers of the engine and it looks pretty straight forward but im worried about getting a socket on the glowplug near the bulkhead as there doesnt seem to be much access,do you remove the pipe that goes into the fuel rail it has a white clip on it,do you pull this clip or pinch it to rempove the pipework while you are changing the plug.
sorry for so many questions but i have to do this work myself as the car has been costing me a fortune lately
52 plate c220 cdi
thanks simon
52 plate c220 cdi
thanks simon
