Door mirror/reverse gear
EmilysDad
Bury Lancs
ML350
I'm away at the moment so can't RTFM :)
It's come on before but assumed that some how I'd caught the button ....
When I select reverse gear, the light for the adjusting driver's side door mirror lights up ..... :confused: :confused:
Confused ..... ;)
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
Your online manual is here:
https://moba.i.daimler.com/baix/cars/w166/en_GB/index.html#emotions/Startseite.html
The light means you have set the dip function on the door mirror when you select reverse. You can set either or both door mirrors to dip on engaging reverse. You turn the ignition on, not start. Push button for which mirror, select reverse, then adjust dip position, release button and put out of gear, turn off, its set
EmilysDad
EmilysDad
Bury Lancs
ML350
The light means you have set the dip function on the door mirror when you select reverse. You can set either or both door mirrors to dip on engaging reverse. You turn the ignition on, not start. Push button for which :)mirror, select reverse, then adjust dip position, release button and put out of gear, turn off, its set
Ah! Thanks for that ..... I'd a feeling that my car should do that as it has memory seat/column. I'll have a play tomorrow :)
keefysher
Hampshire
Andy, here is the script from the manual:
Screen Shot 2019-03-14 at 20.29.11.png Screen Shot 2019-03-14 at 20.29.36.png
EmilysDad
EmilysDad
Bury Lancs
ML350
These Germans are clever ..... ;-)
grayb
Kent
E350CDI (S212) 2010
Not that clever - they only include the function if you have memory seats, which seems a tad mean.
keefysher
Hampshire
Does this feature only work with memory seats?
The inserted screenshots came from my W166 manual. The first doesn't specifically say memory seats, why not give it a go? See what happens.
I did see a video on a non memory seat where the guy said it works on other models:
Capra
Gloucestershire
W204 2013 C350 CDI Pan roof
Be right back.....
grayb
Kent
E350CDI (S212) 2010
Made it back :). It looks like this feature is only available with memory seats, did some Googling, and that appears to be the general consensus.
Exactly what I found with the W212...
keefysher
Hampshire
but did you have a play with the actual car? not everything is on google :confused::cool:
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Yes, definitely only with memory seats. I presume this is because the system doesn’t know where to revert back to after dipping if it does not have a memory for the normal setting.
Capra
Gloucestershire
Makes sense when you think about it.
EmilysDad
EmilysDad
Bury Lancs
ML350
  • #17
Meanwhile ..... I had a play with the mirrors thus morning & my passenger mirror now dips when I select reverse :)
EmilysDad
EmilysDad
Bury Lancs
ML350
  • #18
It still puzzles me as to why the interior mirror isn't included with the seat & door mirrors ..... my 1999 Omega's interior mirror was.
My W213 would dip the passenger mirror (if I left the selector on pax side) and I didn’t have memory seats.
Tel: 020 8863 9233
