Ian Shepherd
- Aug 2, 2009
Hi all,
I have just replaced the drivers-side window regulator on my S-430, the display now indicates "door open" all the time and the computer chimes at me at low revs. Can anyone tell me what might be causing the problem?
Also, having had the battery disconnected for some time, driving the car now feels strange at low revs - it's as if the car is hesitant about pulling away (feels OK at speed though).
It may be totally unrelated, but I've also noticed that the memory steering wheel does not return to the 'park' position when the key is removed from the ignition.
Any thoughts? Is there some sort of Comand reset that might cure the problem?
It's an odd thing but my SRS light has been coming on intermittently (and completely unpredictably) for more than a year. Now that I have replaced the regulator, this indicator has not been on since...probably just a coincidence...
It's always the same isn't it...these things always seem to happen when you want to sell a car!
Ian
Ian
