DPF- Inlet Manifold
David1968
2011 E220cdi sport coupe AMG
I recently posted i had an on going issue with my engine management light coming on every 1kmls, and car not doing re gen, merc specalist checked my E220 CDI AMG 2011 plate over & diagnosed a crack on the inlet manifold, has anyone heard of this before.
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
Iv had a broken broken bolt on the inlet manifold in the past. Apparently it's common. In my case bolt needed drilling out and a new inlet manifold.
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
Ask to see the evidence?
Uncle Benz
West Sussex
Mainly Mercedes
Yes, quite common at that age point. It’ll almost certainly be the second bolt in from the front on the bottom row
One I did a long time ago. I’ve lost count of how many I have done since then!
Exp21
Italy
s204 C200 CDI Blue Efficiency MY2012, w245 B200 CDI Facelift
Hi, I've heard of crank on inlet manifolds. You can find also some videos on youtube if I remember well. Let us know
David1968
David1968
Thanks, the garage is saying due to a crack on the inlet manifold it causes a vacume hence why the car DPF wont re gen also it wont reach heat level! Just hope there correct, dont want to buy the inlet manifold and there wrong.
Uncle Benz
West Sussex
Mainly Mercedes
Ask them if they have a smoke machine to confirm their diagnosis
Exp21
Italy
clarify with them that if it's the wrong diagnosis you'll pay only the spare part and not the job. And you'd be even too kind. They must do an accurate diagnosis before doing such a job. Anyway I remember of a youtuber who diagnosed this with a step by step explanation on a w204 c220 cdi, try searching through the trouble code on youtube
P.S.: if he calls himself Merc specialist, he shouldn't have doubts about the issue
David1968
David1968
They said they did a pressure test which identified it. Its a big ticket number supplied & fitted, just need it fixed but dont want ripped off.
Uncle Benz
West Sussex
Mainly Mercedes
You can fairly reliably confirm it yourself. With a torch you can look down behind the oil filter housing. There is a ribbed aluminium oil cooler down there bolted to the side of the engine block. It should be bright and shiny. If it’s black and covered with oil the intake manifold is leaking
David1968
David1968
Perfect, many thanks fir this advice.
Uncle Benz
West Sussex
Mainly Mercedes
Pics shamelessly robbed from the thread I linked to in my earlier post
David1968
David1968
Where would be best place to get this manifold and how do i know exact spec of my car so i can buy the part.
Dean Fletcher
Penrith, Cumbria
Mercedes S63 AMG
Grangemouth Mercedes. You can get discount aswell for being a member here. I'd expect to be paying around the 300 mark for a new manifold
www.W140.co.uk&www.r129.co
