Dyson has scrapped its electric car project
Tony Dyson
Tony Dyson
God's Country
2014 C 220 CDI W204 OM 651
  • #101
Well I think the actual figures posted above at #99 confirm my figures, if a 40kW boiler (Existing) is raising the water body temp by 1°C in 2 Hours it would take twice the energy to raise the temp in one Hour X 10 for a 10°C increase, there was a typo in my last post actually it should read 10 Hours not days but would still require a c72kWH source.
ajlsl600
france
doubt theres any cheap way to heat that volume in winter ,just cheaper than ? and i suspect ASHP will be the best of bunch.
Tony Dyson
Tony Dyson
God's Country
  • #103
That would be a moot point ajlsl600, with Electricity currently around 5 x the cost of Gas per kWH, depending on where you are in the UK it would need a thorough investigation to reach a conclusion, and the initial investment I suspect would be prohibitive?
ajlsl600
france
ok i am not a fundi on pools but its about the best way right now to help heat my house if i proceed next spring. i esp if its a self install ,i am not in the uk. i am not expecting to stop oil use,i am expecting to substantially reduce oil use ... my rads are over spec,ed so with a buffer tank and some sweat i expect to be able to install for under 7to 8k if that reduces my oil burn by 1000 E i am expecting a 10yr payback and with maintenance, replacement should be beyond my concern
Tony Dyson
Tony Dyson
God's Country
  • #105
Well I'm sure you've done your homework, Oil can't be a cheap fuel wherever in the world you are, and with a dual fuel installation you will have the added benefit of a backup if one fails for any reason!
Frontstep
T210 320cdi
Looks like I'm with gas till Jeremy tells me to get me on Electric or tells me to shut it down.
Then I will have to revisit solar, thanks everyone.
Frontstep
T210 320cdi
If Dyson mades car they would be ;
Overpriced.
Garish.
Flimsy.
A triumph of expensive design over cheap manufacturing.
A plethora of filters and seals with the life and strength of a butterfly.
Instantly trendy on bookface with snowflakes.
Theoretically wonderful.
Practically a nuisance.
Not up my drive
