E class w212 stuck in P column shift
matteb63
Abergavenny Wales
Cl 500s & CLS500 with LPG conversions
e class column transmission stuck in park
speedtronic warning abs ,anti skid warnings all appearing on dash when car started up
changed the f32 pre fuse box ,brake light sensor and tested both batteries to be good.
pressure washed car before ..so wondering if it could be a speed sensor on front wheel
how can I test a wheel speed sensor
anything else I can check?
M
matteb63
Abergavenny Wales
  • #2
would a speed sensor on front wheel cause all these faults on dash?
onefortheroad
uk.
You changed brake light switch ?
Who installed it and how .
Why did you change pre fuse box in the first place .
M
matteb63
Abergavenny Wales
it was suggested that the relays fail in these boxes ,and the brake light switch had also been suggested as a possible issue ,I changed both these . I have a diagnostic set up but its not working at the minute so im trying things that are fairly straight forward before I have a breakdown collect
You need to plug it in and the very least. Could be wheel speed sensor, could be CAN comms with ABS module.....
M
matteb63
Abergavenny Wales
I dont have diagnostics unless I have the vehicle triggered to Mercedes which is not exactly inexpensive...
I understand that it might be a module or can but how would I test the wheel sensor..is there a way
Yes, there is a way, by using diagnostics!!
Or rolling the car downhill in neutral and seeing if the speedometer moves.
Why not use a non MAIN dealer.
M
matteb63
Abergavenny Wales
it seems like I can remove a wheel unplug the sensor and attach a Volt-metre
if I spin the wheel hub it should create a voltage ..if it dosent its a failed sensor
can anyone confirm this test...?
M
matteb63
Abergavenny Wales
if I could move the car out of park maybe your suggestion would be useful ..thanks anyway
The whole idea is to do the checks I can easily before having it collected on a trailer ...lock down has crippled us financially so we have limits to what we can do right now
If its a hall effect type sensor, you cannot test for voltage if its 2 pin and isn't then you can.
onefortheroad
uk.
So you changed pre fuse box because of these errors, no change
Changed brake light switch - no change
And the same faults exist because you used a pressure wash .
if its hall sensor can I not leave it plugged in and test with a volt meter ?
You will have to back probe the connector from inside the car.
M
matteb63
Abergavenny Wales
car was pressure washed earlier in the day maybe 4 hours ..im not saying thats the reason although I have read about someone experiencing these issues after pressure washing their own car...im simply trying things the im able too before calling the truck.
onefortheroad
uk.
I thought id done the same when I pressure washed my e350 , mine turned out to be the earth from the abs pump wasn't earthed , the nut had come loose or been left loose after some repair ??
I had no speedo, no abs , no pre safe , no power steering , no cruise control,no anti collision , rear lights would stay on as if the brake pedal was being pressed. Struggled to get it out of park ,when it did go into drive ,it would engage 3rd and bang down to 2nd then 1st . Reverse could be selected but applying revs the car wouldn't move.
Have you tried half a push to get to neutral ,then try drive ?
M
matteb63
Abergavenny Wales
  • #17
Wiggled the front wheel speed sensor and all the warnings disappeared and gear change normal but two minutes later problem returned ..so I replaced the sensor but no change..
onefortheroad
uk.
Did you use a genuine sensor ?
