E L epc fault. 220 cdi auto 2003 . Advice please
Tony H8
220 cdi avante garde automatic 4dr 2003
I've just bought the above car 47k from new. No service history.
Drove it home from Sotland to Warwickshire. Drove beautifully for three days and about 500 miles. 4 days later I tried to start it from cold. And the problem started....
It started then cut out. Displaying E L EPC fault code. After a few more attempts it started. I drove it for twenty miles (drove as well as before). Switched off for an hour tried to start it again took several attempts. Displaying the same E L fault code. The display continues to read EPC whilst driving.
Tried to figure what changes might have affected it before difficulty in starting.
1) I ran the fuel tank down to less than 1/4 full. The day before.
2) Then filled up with supermarket grade diesel
3) The outside temperature dropped by several degrees.
4) I left the parking light on overnight. (This didn't seem to flatten the battery).
Other possible factors:
5) It's a low mileage car, maybe missed some essential servicing.
6) The seller advised me he always used premium grade fuel.
I hope someone can shed some light on this problem and offer some advice.
Grateful for any expert help. Tony
It needs plugged into a Star diagnostic kit to know for sure, my starter for 10 would be CPS ( crank position sensor).
Find a Mercedes Independent service garage and get the codes read, saves a lot of guessing
You have a good one here quite nearby you
https://www.mercland.com/
Jay Manek and the team know Mercedes cars very well and have the right kit
T
Tony H8
T
Tony H8
Thanks John. I appreciate your advice.
As a postscript. I tried to start it this morning the same pattern occurred. It started first time from cold. Ran momentarily then cut out after a few moments. It then took several more attempts before it started. Then ran perfectly . It restarted easily when still hot. No suggestion of cutting out while driving.
I will contact the garage you suggested. Thanks again for your kind response.
No problem hope it works out for you Tony
carlls
grimsby
2005 cls350 gone 2009 320cdi sports estate
hi tony and welcome to the forum
