E190 heater motor
newlifer
I have a problem with my heater motor , ithas a mind of its own, does run continously, someone said the route to get to the heater motor is through the wiper motor, how does the wiper arm come off so i can get to the wiper motor then to the heater motor
Ian Brown
Banned
There are three bolts on the wipe mechanism two of them are just under the windscreen
The other one is on the black panel between the engine & the heater motor. You don’t have to remove the blade or the arm it all come off in one unit.
anyweb
Sweden
www.niallbrady.com
c238,w120 (diesel)
theres three or four (maybe five cant remember) nuts holding the wiper arm assembly in place, simply remove them, disconnect the wiring and gently man-handle the wiper arm assembly out.
that's the easy part, the hard part is getting the plastic shroud covering the heater blower motor out, i cracked mine slightly on the way out (forced out) but it all worked in the end
cheers
anyweb
