I have pulled the heater motor and everything seems good , I am wondering if the heat controls are run by the vacuum system? The problem is that the heater motor will not run continuely, has a mind of its own. the problem started when i got the car back from the local dealer for senser replacement for the clutch fan. Any thoughts out there as to were i should look next?
