E200 Kompressor, Misfire due to ecu shutting injectors down.
Tony Sefton
Hi. This is My First post, So go easy with me. :) We are working on a 2001 E200 Kompressor that shut's 2 injectors down if you floor the throttle to get kick down. ( Automatic ) or if you hold it in a lower gear and hit around 4100 rpm. This happens every time you do this, But will drive Steadily around all Day as long as you don't hit 4100 RPM. We have checked Fuel pressure, And Exhaust Backpressure, and Tried new Plugs, coils, Air Flow Meter, Crank sensor etc, We have reset Adaptions, and done the crank sensor re-learn without any success, This is a Meevo system and As we understand it, It senses Cylinder misfire by Measuring Crankshaft speed, it appears to be detecting a misfire and shuts the injectors down to prevent Cat damage. ? We have also checked Compressions and no 4 Cylinder is 140 psi and the highest one is about 154 psi. Would this be enough to cause the ecu to detect a misfire,? or could we be looking at an ECU or another Mechanical problem. ? Any advise appreciated. P.S. This car has just been bought through the trade by a Dealer and will most likely have been traded in due to this fault not been rectified by the dealers for the previous owner. ?
Oh, and the only fault Logged in Engine, ABS, or transmission is Cylinder 1,2,3, or 4 Misfire deteced, ( one at a time.) Thanks Tony Sefton.
T
Tony Sefton
  • #2
Looks like not many Merc owners have come across this problem. ? I did talk to one technician Yesterday and he say's that he had a similar fault on one and it was caused due to cylinder imbalance and his compressions were between 140 and 160, Not too far away from our readings. ?
psmart
I havent personally any relevant experience to this fault, but have a suggestion.
Have you considered using diagnostics to run a live data analysis on the injectors, to ensure the cold and hot opening times are correct, and more importantly, at 4000rpm, then 4200rpm? A possibility could exist that the ECU transistors are no longer to spec and are not delivering full power.
Other similar possibilities could be primary power (+ and -) connections to ECU to ensure full voltage/current is getting to the injectors.
Have you thought about the fuel pump relay, since these things, cut the fuel at 4k could it be parcially faulty. Also the fault could be ign ECU or a coil pack
Malcolm
T
Tony Sefton
Thanks Guy's. Hi Alan. How can you help me. ? As you say thart these Ecu's are Hideously Priced and cannot be repaired. ? I have bought repaired HFM ecu's for mercs and sangyongs before and they have been ok, But I haven't tried to get this Meevo one repaired yet. ? What sort of money are we talking about for a Replacement. ?
Flying Scot
MOZZERWELL North Lanarkshire
SL 500 R129 1995
Surely if it is one that MB cant fix / and have failed to fix :confused: :rolleyes: it has to be something silly and not just a module swap of items like the ECU - i am sure MB are great at module swaps but working and solving on these sort of problems is probably beyond their levels of intellect and expertise. The Volvo 850 has a crazy fault that no one can seem to fix - it just wont start on the key sometimes EVERYTHING was changed - ECU's all the sensors battery starter - oh i forgot to say it will start with a push :( every time. After all the experts including the stealer had a look at it someone on the Volvo forum in the USA said it was 'electronic noise' from the starter motor and ring gear flooding the engine compartment with enough noise to wipe out the signals to the ECU - we did hang a scope on it and for sure it was noisy but without a few more 850's to do a comparison check on we did not know if what we saw on the scope was indeed a problem - pre this we had heard this story and fitted additional earth straps between engine and gearbox and both the engine and the gearbox and the chassis - no joy. The fix was to remove the gearbox and clean the face of the engine block and gearbox to a bright shiny finish where they met - this cured the problem for 98% of the time though when you are in a hurry it will play silly buggers at times. So still a bit confused as to what is going on but it is for sure not 100% fixable at anything like commercial prices since heard on the Volvo forums of other 850's with the identical problem when i told one guy to just push start it he said no way then wanted me to tell him and his garage why it would start with a push and not start on the key. So to get back to the Merc i doubt it is a module problem but with the right gear and the right people with access to a rolling road you should be able to discover what is going on and fix it.
ALAN@ECUCLINIC
WEST WICKHAM 07971 420682
www.ecuclinic.com
sorry tony what i meant was the ign ecu cant be repaired i can repair bosch pms and hfm on merc and ssanyong my mobile number is available so please call me( its not a secret its just that other sites ,mgf , seem to be very aggressive toward paying for services!) my web site too should be available by now
harneet
auckland,new zealand
mercedes e200 1996
misfire
hi...i am new on this site and does not know much about cars...i have mercedes e200 1996 model.....my car stands in garage for 8month...replaced the battery...and srs light comes on....and in neutral when i push speed padale....its goes alright but at 40000 rpm it misfire continously....please help me out.....thanks
Slick_01
Germany Bochum
w211
PMS ECU Problem
i think it is the ECU PMS
if it is the ecu i can help you please dont hesitate to call or Post
www.ckinsurance.co.uk
