e200 T 2001 Kompressor Estate no start!
ray_mac
e200 T Komp. Estate 2001
Have a Dec 2001 E200 T Kompressor Estate, app 90k mls
:confused:
Car got stuck in 3rd, restarted and fine, 10 days later no start in airport, Jump start got going, has not started again. All lights on, no noise on turning key.
Oil found in Gearbox ECU and well, have replaced same, now
told ignition signal going to Engine ECU and no further.
PS 1 Driving light gone.
Any ideas? Week 6 without car.
My Kiddies threatening to fix with mallet.
Many thanks.
Welcome to the forum Ray.
Would you care to pop up the first 6 VIN numbers after WDB
R
ray_mac
ray
You have a starter relay K40/4K2 that could be blown
You have a K40/ 4 fuse and relay in passenger fuse box
R
ray_mac
Does the engine turn over??
no
all lights on
no noise from engine
previously- rear lightbulb problems, now front driver light gone, brake wear warning,
eng ecu bench tested, all fine
geabox ecu oil filled, not repairable
have bought salvaged gearbox ecu from dronsfields
now mechanic( elec auto garage) tells me ignition talking to eng ecu, but
eng ecu not talking to gearbox ecu , not happy with eng ecu, wants to replace, i'm not so sure
thanks
ray
This info is not correct
BlackC55
South coast
C43
I had a gearbox control unit recently that went down causing a non start. It was a weird one too.
It it killed the SAM circuit then its possible
R
ray_mac
how did you sort it out?
ray
R
ray_mac
thanks malcolm
will ask about SAM units, though i think these have been discussed
regards
ray
I tried to look at logically, the car drove home OK once it was jump started,, but failed to turn the starter later,,I could understand the selector module going down and this would stop it,, But it did drive home,,part of the EIS circuit from the switch is another thing apart from the K40 bits in my earlier post
Cole@MBS
www.mbssouthampton.co.uk
Sounds like a blown ecu cooling fan fuse again!!!
R
ray_mac
thanks for input
ray
