Cluster Repairs UK can probably fix it - give them a call. There's other companies in the repair business, too, or you could try various breakers for a used replacement.
Take the instruments out and clean the plugs and connectors put it back in and she how it goes, if not sounds like the board probably needs resoldering. Mine did the same thing 2 years back, I got away with cleaning the connections and it's still working well, so it's worth a try.
