E220 CDI how much gearbox oil for 6speed manual
Haircut
E220 CDI blueefficiency 2011
Hi I am new to the site and after a little help please. I have recently purchased a E220 CDI blueefficiency 2011 model I believe it's A207. With no indication of any problems I lost reverse gear and 2nd after being parked. It has been removed by my father in law x mechanic and seems to be working again so he is going to put back on. I would like to know how much oil is required to refill and have also read elsewhere about a torque conductor and draining this but do not know if my car has one or where it is located.
Thanks in advance.
Naraic
2005 CL500.
If your car is a manual it will not have a torque converter.
steveq
Dublin
I changed the gearbox oil in my manual 2011 C220 CDI which has the same transmission as yours, I assume.
I researched it and found that the capacity is 1.5 litres. You don't fill it until it overflows.
H
Haircut
That's awesome Steve v much appreciated couldn't find it anywhere! I'm going to buy a full repair manual I think, seen on eBay only £10 problem is it's 60gb file so need a better laptop 1st.
Thanks again
steveq
Dublin
You are welcome.
By the way, I have read that those repair manuals cover US spec cars only so diesel engines (and probably manual gearboxes) won't be covered at all.
