E220 fan problem
michael101
cumbria
2001 E220 cdi
2002 E220. The fan is working fine but there is no air flow - hot or cold - out of the vents. Something stuck? In this weather quite happy to jam it full on if there's a way.
Any solutions?
Cheers
Mike
The car will have to go on STAR to see what has failed in the heater box, the flaps could need a re set.
A good indie is the cheapest way to go
michael101
cumbria
2001 E220 cdi
Cheers -also connected problem?
Car also stuck in limp mode - had planned to get the diagnostic thing done - could they be connected?
Should explain this is an old car -320K miles - had it from new - only does motorway driving and has been excellent except for bodywork. Running it until death but trying to keep it going a bit longer.
Cheers
Mike
Been thinking, is the car a 210 for the heating in those is simpler, are all the fan speeds working, and no nothing to do with any limp home, That will need STAR,,,no reason not to keep it running
michael101
cumbria
2001 E220 cdi
Type 210K
the type is 210K - all fan speeds are working from off to high .... Would love to keep it running if it doesn't get too costly and falls apart - bodywork was a friday nighter.
Mike
lwbnick
wales
euromerc.tumblr.com
expedition
Any solutions?
Cheers
Mike
Is your pollen filter blocked up with cack?
michael101
cumbria
2001 E220 cdi
Where is the pollen filter located?
Never changed the filter - don't know where it is - any pointers?
Thanks for your help
Mike
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
michael101
cumbria
2001 E220 cdi
after dismantling everything...
Took the filter out (finally found it underneath right next to the blower after taking out glove box, kick panels etc). You guys were right - air flow normal now. Thanks for your help.
Mike
