E220D smoke from oil filler cap
J
jjmorris90
E220d
  • #21
We've had a few of those reported now, hence the question- that's one hell of a price. Have you found yourself a Mercedes Independent yet?
Nope. I’m in Leicester and seems to be only the main dealer around here. They did say I can buy a second hand tank and they will fit it. Though I’m sceptical of it having the same issue
if Nottingham isn’t too far then Mercserce. Roger and Nate top blokes.
J
jjmorris90
E220d
  • #24
The bit that you screw the oil filler cap onto is if you like an upside down saucepan, Look for any hose connected to this saucepan. That hose is part of the so called 'breather' system. You can follow that hose to see the next item in the breather system. Please put up some pictures.
Is it this
mattkh
England
A160 W168 1999 1.6
Thank you for the photo. Unfortunately, I cannot make it out clearly. Sorry.
By the way, please tell me the engine code, should be OM something.
J
jjmorris90
E220d
  • #26
Just a follow up. Car is running fine replaced the ad blue tank but check engine light remained. plugged it in and got these readings?
Pending faults are in the current drive cycle. Go for three seperate drives in one day. If they occur each time then they will be stored and it needs seeing too.
Need Xentry for those codes, current means it's occurred once during current engine running session. Look for a wiring issue around those sensors, but my opinion is the code definition is wrong, as the car wouldn't run with a rail pressure sensor shorted to ground.
J
jjmorris90
E220d
  • #29
all codes are wrong or just the fuel rail one? Any idea where the sensors are? Could this still be related to adblue? Perhaps I got another dud unit from eBay
First two codes
Adblue one is stored but not current, and you would usually get something like that in the engine ecu when the tank sensor fails.
Rail pressure sensor is at the end of the rail. As I say though, take those with a pinch of salt....
J
jjmorris90
E220d
  • #31
First two codes
Would the stored one still cause a check engine light? Or is that the two current ones only
mattkh
England
A160 W168 1999 1.6
Please tell me the engine code.
mattkh
England
A160 W168 1999 1.6
Ya. Which one is it. OM 6.... something
The stored one will erase once you erase the codes, so you can ignore it
J
jjmorris90
E220d
  • #37
It’s worth noting, in the engine bay after I got it serviced. There is the air filter and underneath that there is supposed to be two bent rubber hoses. I assume air intake outtake. One has vanished so don’t know if that is causing any issues
