E270 Cdi. No EML, no boost. Tried a few things and.....
BigAlMercMan
Birmingham
2003 S211 E270 CDi Elegance
Had the old girl 10 years now, I got load of help on this forum getting a few things sorted out when I first had it. But I'll be honest, it's done the last 80k with only having the basics taken care of. I'd really appreciate a bit of help now.
Accelerating the other day there was a bang from the exhaust and instant loss of power, kangarooing at low revs. The car sat on the drive for a few weeks and I was close to getting rid of it but thought I'd give the RAC a shout first and take it from there.
Some good advice later and I've cleaned the EGR in and out and I'm sure that's working properly, but still no boost, had look at turbo inlet seal and it doesn't look too bad, turbo spindle also nice and tight .
Then I noticed the pipe below hanging out and with a clip missing I think. No idea what it is or what it does or if it could be the cause of my problems.
I need some help identifying the connection in the pic if anyone can help please, and is it worth finding the clip and resealing? I hope this solves my problems but on the other hand I'd like to get a good old thread going.....
B
BigAlMercMan
Birmingham
  • #2
Just to add I've got fault 2346 'egr control - the air mass is too large' so I'm hoping the pipe hanging off is my issue.
Steve@Avantgarde
Bristol/Somerset
If the air mass is too large it points towards a blockage and the engine cant breathe properly. I would say the top KAT has broken up and its restricting the exhaust. Its probably the reason its blown that pipe off.
star
Reading
Smart + others :)
At a guess as pics not clear, it’s either the turbo outlet plastic connection that connects the o/s turbo intercooler pipe to turbo or a boost pipe connection to intercooler. Both Common failures and need replacing to contain boost pressure.
mioba
Nottingham and Köln
Something upsteam of that hose has caused it to blow out.
Font pfaff about sealing it, get a replacement hose and clips from merc.
umblecumbuz
Wales and Gozo
Yes, buy replacement pipe and fit it - but sort the basic reason first. As Steve above - why did it blow off? A blockage creating excess pressure is probably the reason. No point in just replacing the pipe without first finding the cause.
mioba
Nottingham and Köln
dont, sorry typo on iphone
star
Reading
Smart + others :)
The plastic fitting or intercooler gets brittle and sometimes fractures when under boost. Just replace fitting or intercooler which ever is broken. Rarely an overboost fault, just old age.
B
BigAlMercMan
Birmingham
This really is a great forum, thanks for all the advice and a bit humour.
My first suspicion was a collapsed cat, honestly! The way it drives (or doesn't) just feels like there's some restriction.
I'll inspect the intercooler hose sorted and see if I can confirm if it's blown off or just old age.
Next have a look at the exhaust, I don't want to fit new parts for them to break again obviously. The car is running so I should be able to tell if there's a restriction. Is there a way of checking the cat without major disassembly?
I can't find any on the net but I'm guessing the cat and manifold ain't going to be cheap.
B
BigAlMercMan
Birmingham
Took the intercooler hose out, no surprise it's not stopping in there!
I still suspect a blockage somewhere else, I took outlet hose off to inspect it and there's oil running out where it connects to the intake box.
Trial and error though I suppose?
