e280 124 spark plug access
Dexter
Devon
Anyone now how to remove the wide plastic pipe which sits accross the block to the air cleaner and prevents the spark plug cover panel to be lifted. The haynes manual shows the underbonnet view but overlooks this problem in the spark plug renewal section.
worried about spark plug compatability as champion plug listed in Haynes manual is C10YCC and my local motor factor says it should be C11YCC
should I be worried about tightening torque ? or simply apply common sense and tighten just above hand tight with spanner.
Oil filter looks a little inaccessible do I need to remove anything else around it to when changing oil ?
Grateful
