E280 starting and idling problems
Status
Not open for further replies.
loucummins
Oxford and Newbury
I bought a very nice L reg E280 in December. The engine melted within three weeks, re-manufactured by Crewe engines at a cost of £4,500. Ouch. Before and after the re-build, the car is a poor, slow starter. The battery is new. Also misses on tickover when in drive. Drives beautifully and in view of expenditure I shall keep it. The only other clue is that the dud bulb light goes on and off when the lights are on - seems to be affected by hrw and braking. Any bright ideas? After a good experience with an elderly BMW 525i, I want to convery to lpg but electrics must be sorted out first. Thought of having ECU tested but the number cannot be traced, even by MB experts.
sunil sood
re the dud bulb warning-have you checked the rear brake light bulbs,number plate lights and also if you have the wrong wattage bulbs,they will work but the warning light will come on.
Neilc
West Sussex
1972 300 SEL 6.3
Sounds like you have significant voltage drop somewhere or a problem in the charging system. I would have an auto electrician check out the alternator and ground straps, battery connections etc. HRW, brake lights etc all suck a lot of amps. A high resistence ground will give you poor starting problems. HTH, Neil.
Status
