E300D Diesel Pump
Nigelkellyjones
Rotherham
I have been told by my garage that I need a new Diesel pump for my 1995 E300D. I know this is going to be ****** expensive but just so the guy doesnt have my pants down, does anybody know how much I should pay for a recon pump?
Parrot of Doom
Manchester
If you look on www.eurocarparts.com and enter your vehicle details (parts), then move down to engine parts>diesel pump parts, there are a few in there depending on exactly what model you have.
I saw two, one at £130, and another at £200, but I'm not certain which model you have. Not too expensive though, and I would imagine its a fairly simple DIY job.
Bumper
Banned
That price is for a vacuum pump for the brakes not a diesel injection pump.
His car is a 300 diesel the pump in question would cost roughly 10X the price of the pump from euro and that would be to get it reconditioned.
several points here.
Have you had a data read out,
Does your garage mean the fuel pump or the distributor injection pump,if its the fuel pump that unbolts from the distributor pump.
how did the car behave when it went wrong
Malcolm
Parrot of Doom
Manchester
If thats the price, I'd buy an entire car and strip it! :eek:
Bumper
Banned
Do you mean the injection pump itself or are you talking about the diesel lift pump
Injection pumps are expensive you would be better trying to get a second hand one or putting your into a diesel specialist for an overhaul. If it’s the lift pump I cant see it being that expensive because its just a small mechanical pump to supply the injection pump.
whitegold
East Yorkshire
C220 cdi Blue Efficiency SE MY2012
Try speaking to Surestart at 'Donny
Unit 12, Shaw Lane Industrial Estate, Doncaster, South Yorkshire DN2 4SQ
01302 340467
To my experience, they will not be after more of your money than absolutely necessary. (I've used them several times over the last 20 years, always cheap and 100% honest)
Good luck
Simon
N
Nigelkellyjones
Rotherham
Hi Guys. Thanks for the replies. It is the injection pump that is the problem. Not the lift pump. The car is completely gutless. I know it is a heavy motor but I need to keep my foot pressed to the boards most of the time. Also, until it warms up, it is misfireing. I have replaced the heater plugs and used injector cleaner. If it is going to cost me a grand, then I will just put up with it for the time being
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Gutless diesel
Have you correctly adjusted the throttle cable and the kickdown cable? If they're wrong the car will be as flat as a pancake
Is the EGR working OK? Does the valve close at about 2600 rpm then open again?
Does the car bang shifts or not? Lots of hydraulics on the late diesels and not all is what it seems
I had one that was as flat as anything & reported a rack sensor error on Star Diagnostics. I took it to the local diesel specialist and they adjusted the cables correctly and the car was transformed. Reason for the rack sensor error? No rack sensor fitted to the car...
I'd make 100% sure everything else is OK before throwing £1000 at it
Nick Froome
www.w124.co.uk
clive williams
Nigel,
Try taking the motor into a diesel specialist not an MB stealer or indie. They usually love stripping them down repairing/refurbishing - its their commercial background. It'll be a damn site cheaper than with the car fitters.
Clive
500E
E320CDIT210
Do as all these people have said, Get it checked out by someone who knows
Bosch have a new program of deisel exchange parts. When you are sure it is the pump, ask Parts Co for a exchange price.
Malcolm
Tel: 020 8863 9233
