E320 CDi Front Tyre Wear
chancha
if both front tyres are wearing on inner and outer edges this is what you would expect. ideally tyres will be used on both axles equally to get maximum wear from them, tricky if you run bigger rears. this is a trait on pretty much all RWD mercedes cars.
thanks Alexander, surely only getting 3000 miles from the fronts is a bit extreme and points to some kind of wear and tear in the front suspension setup?
dieselman
A diesel
More likely it points to under inflation coupled with wide wheels and using the power steering when stationary.
jberks
As dieselman - under-inflation will result in more wear on the edges and less in the centre - over inflation more centre wear and less edges.
Increase the pressures until the wear pattern is even.
Frontstep
T210 320cdi
I have a 210 and have to agree need about 32 to even things out for me on Michelins
Chevril
Gillingham, Dorset, UK
www.chevril.com
E350 Diesel Estate - 2012
Hi All, I've got inner tyre wear on front offside only... I took the wheel off to change the drop links and the tyres is split down to the metal inner casing... as I was about to do 300 miles on tuesday.... I'm in a quandry...
If i simply change the tyre, I'm in exactly the same position... so is the recommendation to change springs and camber bolts?
harpersimon
Southwest
2015 A200 AMG line
For the cost, change the bottom swivels.. Or you'll just keep putting tyres on it,
