E320 cdi
Naraic
2005 CL500.
Welcome to the forum.
Was that a question? Text speak would have saved you even more time.
Sounds like the starter is jammed.
Corned
East Midlands
2005 S211 E320CDI Avantgarde
In my expert opinion, I'd say that something was wrong somewhere.
(As best I can tell from the information supplied...)
steve sims
london
e320cdi 51plate
Thanks r they easy 2 change
steve sims
london
e320cdi 51plate
everything works ok but when trying 2 start it nothing
Naraic
2005 CL500.
i din no
Frontstep
T210 320cdi
I think you will have to use a few more letters because if everythings ok ?
It maybe you need to see if you have 12volts at starter motor ?
It may just need a sharp wack to the starter motor.
If the battery is flat or low the starter will kick in and stall drawing excessive current
Frontstep
T210 320cdi
It may be as said a seized starter.
init :p
Also WG, I have moved to harrow recently, im about 5 minutes away from you. Might come and bug you more often now :p
init :p
Phew,, with my lousy glasses I thought you said hug you :D
Frontstep
T210 320cdi
wot hpnd to txt spk i ws lrng lds abt m mrc str?
