E320 with 722.6 Autobox - Oil Leaks
John472
My E320 W210 had a transmission rebuild by a professional automatic specialist. Unfortunately they were a victim of the recession last year.
I took the car to another specialist who fitted a new electrical switch and 'o' rings to the 722.6 but when I got it home I still found oil leaking.
I am getting a bit fed up with this now. The car has not done a huge milegage since the box was rebuilt and should not be leaking.
Does anyone have any first hand knowledge on what might be causing this?
I am assuming it is not anything stupid like the oil pan gasket, as this was checked about 6 months ago and the oil and filter was changed as a precaution 1000 miles after the rebuild.
Thanks,
John
MB Service Centre
Mansfield
www.mbservicecentremansfield.co.uk
A210 E320
Its hard to pin point over internet, but it could be the gasket. or the drain plug, or poss last person who did the job last tightened the switch seal conector to tight and stripped/ snapped it off internally. need looking at asap.
LYNALL
Kent
Easiest to run it up a high kerb somewhere and get underneath and have a look?
Are you sure its atf thats leaking as my wifes w203 c320 has a leak that looks like it coming from the gearbox but is actually the engine rear main seal leaking.
Lynall
J
John472
Lynall
Not very practical though - You have to remove the underbody shield first.
Then you need to clean everything up before you can see what's going on.
Not the sort of job I would want to do lying in a gutter.
A
andy@pcd-ltd
It could be the gearbox pilot bush connector that is leaking it is quite common on these gearboxes.
But again you would need to get underneath and take the undertrays off and have a look
J
John472
I am not familliar with this part.
Can you tell me whch side of the transmission it is located?
Is this internal or external to the oil pan?
It is on the passenger side, Can you not get the car on a ramp for 5 mins to take a look
