E320cdi w211 gearbox oil spec
bruces670
E320cdi 2008
is there anybody that can confirm what spec oil will go in my auto gearbox? Thanks
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
Even if it is a 722.9 7 speed it will also be spec 236.14 (this is red)
The later 722.9 gearboxes (called the 7G+) changed to a spec 236.15 (a blue/green colour). This was introduced in late 2010 with the move to with stop/start but (AFAIK) some cars without stop/start had this auto box too.
The two specs of ATF aren't miscible and the 236.15 shouldn't be used in the earlier box. Anyway, the 236.15 is more expensive.
B
bruces670
E320cdi 2008
I believe mine is 722.9
B
bruces670
E320cdi 2008
7 speed
B
bruces670
E320cdi 2008
I think it’s that?
steveq
Dublin
Yes, but ... it says 'complies to the specification of'. That isn't the same as Approved by MB.
Fuchs is MB approval 236.14 MB spec , I just checked on Opie oils website (and the back of my Atf4134 tub)
B
bruces670
E320cdi 2008
I’m planning on replacing my torque converter
B
bruces670
E320cdi 2008
I’m on 150k miles,I’ve been a mechanic for nearly 30 years off and on,plus I’m not paying 1500 to have it replaced
B
bruces670
E320cdi 2008
What did you use as a one way valve to put the oil in?
Check out my diy link above buddy , it's all there , maybe in another 30 years I can call myself a mechanic :D
B
bruces670
E320cdi 2008
  • #18
How important is it that you monitor the gearbox temp?
AMGeed
Poole, Dorset
S204 C180K
^ Very. You'll get a different reading if the ATF isn't up to temperature when measured (80C IIRC).
B
bruces670
E320cdi 2008
  • #20
Is the plastic level indicator mounted on the filter?
