Markieboye
- Nov 27, 2008
- Age
- 57
- Location
- Stafford
- W210 E320CDi Estate 255000 miles
noticed occasionally over the past week that the car (W210 320cdi) wont rev past 4000rpm whilst driving.
If you take it up steadily then it will stutter and then drop off. But if you drive it hard then the engine seems to just die - well not quite but the revs drop to about 2500.
Normal driving is fine, mpg is not affected, kick down and general power is good apart from when you hit 4000rpm.
I have swapped out the MAF with a genuine MB one - no change.
Changed the fuel filter and that improved things a little as it'll go up to about 4200rpm but still does the same thing.
I have got it booked in for a diagnostics check tomorrow, but was wandering if anybody has any ideas ?
cheers
Mark
cheers
Mark
