E350 2010 Struggles to start when cold
GaryRob
2010 E350 Diesel
Hi Fellow Merc People. Appologies for my first post here to be asking for help.
My E350 has been having some cold start issues for the last few months. It has no problem starting when warm , just cold.
When left overnight ,In the morning I need to give it 4/5 heats to get it to start. Once it is warm it runs and drives fine, no smoke etc.
Ive pulled all the glow plugs out today and tested them with Jumper cables. All worked fine. I then tested them in the loom, but still out and earthed and can see them all glow again. I can only count 2 seconds of glowing. Is that right?
Ive put it all back together again and its the same. In my mind ive rulled out the Glow plugs and the relay. Any other Ideas please?
No error codes and apart from this it runs sweet as a nut. The only thing I could fault it on is it does run a little cold. 50/60 deg stat change next weekend.
Many thanks for looking
Hello and Welcome,
~85-90 is normal Running temp so you’re very cold
G
GaryRob
2010 E350 Diesel
Thank you.
It will get to temp eventually but it does take some time. I am going to change asap though.
Oldspanners
Normandy
C CLASS 2004 C180
Have a look at this it's a comprehensive guide for a Jeep but the same sort of engine may give you a clue.
andrew056
Devon
1993 SL320 gone but not forgotten , 2004 240 CLK cabrio, 2006 ML 320cdi gone, GLC AMG 43
I thought the plugs were supposed to stay on on the 642 engine so I would suspect the relay to be faulty which is common at that age . Used to be about £120+ have a look on ebay
malcolm E53 AMG
Thank you.
I would get this done ASAP it will affect mpg drastically and probably the DPF. Mine went down a couple of years ago and the engine ran like a pig. My glowplug light stays on about 2 seconds if that helps but I would definitely do the stat first it may have a bearing on your cold starting
andrew056
Devon
I really can't see how a thermostat will affect cold starting , the operative word being cold , it obviously needs changing but won't affect starting.
onefortheroad
uk.
Ive a used relay from a om642 . £30 plus postage if int.
G
GaryRob
2010 E350 Diesel
:) Arrived yesterday morning and I put it straight on. Been out to start this morning on a very frosty day after two days sat on the drive and boom....first go!... New stat on the way later today. Many thanks for all your help guys. Especially onefortheroad for my cheap fix part.
onefortheroad
uk.
Ive a few more to sell you lol. Glad it worked out for you.
onefortheroad
uk.
hi are these relays still available i am having problems starting in a morning
I only had the 1 m8. Have a look on ebay ... new ones are about £86 ??? Beru ..
